Unable to setup a mail configuration with google on Ghost v3.8.
Please find the mail properties on config.production.json
“mail”: {
“service”: “Gmail”,
“transport”: “SMTP”,
“options”: {
“host”: “smtp.gmail.com”,
“port”: 465,
“secureConnection”: true,
“auth”: {
“user”: “@gmail.com",
“password”: "******”
This is the error i’am getting when trying to restart ghost with above configuration.
Did you tried with less secure password on gmail account setting?
& also use downcase
“service”: “gmail”,
@inoryum
I tried both less secure password on gmail, lowercase as “gmail”. But of no luck.
my config.production.json path is: /var/www/ghost/core/server/config/env
Can you check the user has correct permission?
check if the folder have 775 permission
EG
sudo chmod 775 /var/www/ghost
& your current user is the owner of the folder
for Example
sudo chown $USER:$USER /var/www/ghost
@inoryum I did gave it a try, no luck .
Oke last thing can you check on your server if the quotes are this" " instead of“ ”?
Can can you send me a screenshot of your config.json file hiding your password & email?
@inoryum Please find the screenshot of config.production.json
Use the following config i trimed some of config & let me know. I have checked the following in my server working good… Make sure u turned off less secure app from your gmail account
"mail": {
"from": "yourfromname<email@gmail>",
"transport": "SMTP",
"options": {
"host": "smtp.gmail.com",
"port": 587,
"auth": {
"user": "user@gmail.com",
"pass": "password"
Replaced the config of yours, it’s the same error again.
"Cannot create property ‘mailer’ on string ‘SMTP’ "
@inoryum Just FYI, the current versions that I have are
“nodemailer”: “^6.4.2”,
“nodemailer-smtp-transport”: “^2.7.4”,
The nodemailer version used by Ghost is 0.7.1 Ghost/package.json at main · TryGhost/Ghost · GitHub
Did you change this manually @workman?
Nope by default, I have this nodemailer 6.4.2 installed.
Okay, well by default the nodemailer version is 0.7.1
How did you install Ghost?
I would try removing your node_modules directory and running yarn to reinstall the correct versions of dependencies
