Unable to Start Ghost - Cannot find module '/usr/bin/ghost'
I am unable to start Ghost.
  • What’s your URL? This is the easiest way for others to debug your issue
    http://blog.linuxdeveloper.io
    3.13.4 upgrading to 3.19.2
  • What configuration?
    Standard configuration.
  • What browser?
    Firefox
      Stopped Ghost systemd service for blog: blog-linuxdeveloper-io.
      Jun 15 20:39:32 p-eu-web-0 systemd[1]: Started Ghost systemd service for blog: blog-linuxdeveloper-io.
      Jun 15 20:39:32 p-eu-web-0 node[4943]: internal/modules/cjs/loader.js:969
      Jun 15 20:39:32 p-eu-web-0 node[4943]:   throw err;
      Jun 15 20:39:32 p-eu-web-0 node[4943]:   ^
      Jun 15 20:39:32 p-eu-web-0 node[4943]: Error: Cannot find module '/usr/bin/ghost'
      Jun 15 20:39:32 p-eu-web-0 node[4943]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.j
      Jun 15 20:39:32 p-eu-web-0 node[4943]:     at Function.Module._load (internal/modules/cjs/loader.js:842:27)
      Jun 15 20:39:32 p-eu-web-0 node[4943]:     at Function.executeUserEntryPoint [as runMain] (internal/modules/r
      Jun 15 20:39:32 p-eu-web-0 node[4943]:     at internal/main/run_main_module.js:17:47 {
      Jun 15 20:39:32 p-eu-web-0 node[4943]:   code: 'MODULE_NOT_FOUND',
      Jun 15 20:39:32 p-eu-web-0 node[4943]:   requireStack: []
      Jun 15 20:39:32 p-eu-web-0 node[4943]: }
      Jun 15 20:39:32 p-eu-web-0 systemd[1]: ghost_blog-linuxdeveloper-io.service: Main process exited, code=exited
      Jun 15 20:39:32 p-eu-web-0 systemd[1]: ghost_blog-linuxdeveloper-io.service: Failed with result 'exit-code'.
    Upgrade from 3.13.4 to 3.19.2 and try to start Ghost.
  • Steps I’ve taken to try to address the issue?
    I have ran:
ghost update --force
ghost upgrade --force (is this the same as ghost update?)
I have ran ghost doctor and confirmed:
blog@server:/var/www/ghost$ ghost doctor
✔ Checking logged in user
✔ Checking operating system compatibility
+ sudo systemctl is-active ghost_blog-linuxdeveloper-io
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
And then I run
ghost start
No matter what I do, it always fails with the same error that it cannot find the /usr/bin/ghost module. I have confirmed that there does exist a binary at /usr/bin/ghost and that I can call it with /usr/bin/ghost --version.
I am out of ideas. Please help me start ghost!
Thank you.
I solved this.
The issue was that the permissions on the versions/3.19.2/ files were 640 and they should have been 644.
It is unclear why they are permissioned to 640 upon installation, although I was able to reproduce this issue multiple times.
It is unclear why the ghost doctor didn’t show permission errors.
I fixed it by issuing the following command:
chmod -R o+r versions/3.19.2
Total downtime 18 hours.
