I’ve upgraded about 20 blogs today… and all seemed peachy for a while… but now, ghost start is not returning - it loops at the sudo systemctl start ghost_...
prompt and never returns…
syslog says:
node[9194]: Error: Cannot find module '/usr/local/bin/ghost'
node[9194]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
node[9194]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
node[9194]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
node[9194]: at startup (internal/bootstrap/node.js:283:19)
node[9194]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
and sure enough - there is no such file - which
shows that I have /usr/bin/ghost
If I create a link sudo ln -s /usr/bin/ghost /usr/local/bin/ghost
then ghost start
still fails - with a different error:
node[10454]: + sudo node current/index.js
node[10454]: We trust you have received the usual lecture from the local System
node[10454]: Administrator. It usually boils down to these three things:
node[10454]: #1) Respect the privacy of others.
node[10454]: #2) Think before you type.
node[10454]: #3) With great power comes great responsibility.
node[10454]: sudo: no tty present and no askpass program specified
I’ve tried reverting to 3.21.0 by changing the ‘’‘current’’’ link - but the error persists.
Most appreciative for any help!
