I am currently using Ghost using AWS Lightsail.
But I forgot that I should not update the dependencies in Ghost by myself.
So I tried running sudo /opt/bitnami/ctlscript.sh start to get all three service (mysql, ghost, apache) up and it said (excluding the ‘mysql’ and ‘apache’ server is up part and passed check):
Message: The installed node version has changed since Ghost was installed.
Help: Run ghost update 4.7.0 --force to re-install binary dependencies.
and I have tried run ghost update 4.7.0 --force and it seems to not help anything. Nor ghost doctor.
Now my website (https://blog.sagelga.com) is in code 503.
So I tried starting it using ghost start. It doesn’t help and when using Bitnami tool, it still shows the service is down.
and also when I access it, it directs me to 127.0.0.1:2368, which is port + private IP of the Ghost service.
I tried stop, restart from both Ghost CLI and Bitnami tool, and it seems not to help anything.
What’s your URL? This is the easiest way for others to debug your issue
blog.sagelga.com
But the current website is on 503 due to issue(s) -
4.7 -
What configuration?
Attached a S3 storage and set to send mail via Mailgun -
What browser?
any -
/opt/bitnami/mysql/scripts/ctl.sh : mysql (pid 6387) already running
+ sudo systemctl is-active ghost_127-0-1-1
✔ Checking system Node.js version - found v14.15.4
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✖ Checking binary dependencies
✔ Checking systemd unit file
Warning: Ghost is running with node v14.17.0.
Your current node version is v14.15.4.
✔ Checking systemd node version - found v14.17.0
One or more errors occurred.
1) Checking binary dependencies
OS: Debian GNU/Linux, v10
Node Version: v14.15.4
Ghost Version: 4.7.0
Ghost-CLI Version: 1.17.3
Environment: production
Command: 'ghost start --no-prompt'
Doing thenpm upgradeinapps/ghost/htdocs/current(I think)
