"Unknown Error" when attempting to log into admin
I kept getting Unknown error when I tried to log into Ghost Admin.
The installation was done on DigitalOcean using the standard marketplace instructions.
I’ve managed to pull the log, appended below. It looks like
“Unable to determine the authenticated user or integration. Check that cookies are being passed through if using session authentication"
Any troubleshooting starting points appreciated!
— Start of Log —
- Inspecting operating system
+ sudo systemctl is-active ghost_www-pixelpeeper-me    [2020-10-18 03:47:53] INFO "GET /assets/css/dist/main.min.css?v=a95d2d7fd6" 200 18ms
[2020-10-18 03:47:53] INFO "GET /assets/js/dist/all.min.js?v=a95d2d7fd6" 200 15ms
[2020-10-18 03:47:53] INFO "GET /content/images/size/w1440/2020/09/20200910_DTKM_DSCF0372-3.jpg" 200 22ms
[2020-10-18 03:47:54] INFO "GET /content/images/size/w584/2020/09/20200910_DTKM_DSCF0372-3.jpg" 200 2ms
[2020-10-18 03:47:54] INFO "GET /favicon.ico" 200 1ms
[2020-10-18 03:47:57] INFO "GET /ghost/" 200 4ms
[2020-10-18 03:47:58] ERROR "GET /ghost/api/v3/admin/users/me/?include=roles" 403 11ms
MESSAGE: Authorization failed
level: normal
"Unable to determine the authenticated user or integration. Check that cookies are being passed through if using session authentication."
NoPermissionError: Authorization failed
    at new NoPermissionError (/var/www/ghost/versions/3.32.2/node_modules/ghost-ignition/lib/errors/index.js:134:23)
    at authorizeAdminApi (/var/www/ghost/versions/3.32.2/core/server/services/auth/authorize.js:28:25)
    at Layer.handle [as handle_request] (/var/www/ghost/versions/3.32.2/node_modules/express/lib/router/layer.js:95:5)
    at next (/var/www/ghost/versions/3.32.2/node_modules/express/lib/router/route.js:137:13)
    at authenticate (/var/www/ghost/versions/3.32.2/core/server/services/auth/session/middleware.js:24:13)
[2020-10-18 03:47:58] INFO "GET /ghost/api/v3/admin/site/" 200 1ms
[2020-10-18 03:47:58] INFO "GET /ghost/" 200 7ms
[2020-10-18 03:47:58] ERROR "GET /ghost/api/v3/admin/users/me/?include=roles" 403 9ms
level: normal
[2020-10-18 03:47:59] INFO "GET /ghost/api/v3/admin/site/" 200 1ms
[2020-10-18 03:47:59] INFO "GET /ghost/api/v3/admin/authentication/setup/" 200 7ms
[2020-10-18 03:48:02] ERROR "POST /ghost/api/v3/admin/session" 500 24ms
CODE: ER_BAD_FIELD_ERROR
MESSAGE: Unknown error
level: critical
InternalServerError: Unknown error
    at new InternalServerError (/var/www/ghost/versions/3.32.2/node_modules/ghost-ignition/lib/errors/index.js:90:23)
    at Object.handleStoreError (/var/www/ghost/versions/3.32.2/core/server/web/shared/middlewares/api/spam-prevention.js:29:25)
    at module.exports.<anonymous> (/var/www/ghost/versions/3.32.2/node_modules/express-brute/index.js:133:21)
    at tryCatcher (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/util.js:16:23)
    at Promise.errorAdapter (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/nodeify.js:35:34)
    at Promise._settlePromise (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/promise.js:601:21)
    at Promise._settlePromise0 (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/promise.js:649:10)
    at Promise._settlePromises (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/promise.js:725:18)
    at _drainQueueStep (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/async.js:93:12)
    at _drainQueue (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/async.js:86:9)
    at Async._drainQueues (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/async.js:102:5)
    at Immediate.Async.drainQueues [as _onImmediate] (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/async.js:15:14)
    at processImmediate (internal/timers.js:456:21)
    at process.topLevelDomainCallback (domain.js:137:15)
Error: ER_BAD_FIELD_ERROR: Unknown column 'NaN' in 'field list'
    at Query.Sequence._packetToError (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/protocol/sequences/Sequence.js:47:14)
    at Query.ErrorPacket (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/protocol/sequences/Query.js:79:18)
    at Protocol._parsePacket (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/protocol/Protocol.js:291:23)
    at Parser._parsePacket (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/protocol/Parser.js:433:10)
    at Parser.write (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/protocol/Parser.js:43:10)
    at Protocol.write (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/protocol/Protocol.js:38:16)
    at Socket.<anonymous> (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/Connection.js:88:28)
    at Socket.<anonymous> (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/Connection.js:526:10)
    at Socket.emit (events.js:315:20)
    at Socket.EventEmitter.emit (domain.js:482:12)
    at addChunk (_stream_readable.js:295:12)
    at readableAddChunk (_stream_readable.js:271:9)
    at Socket.Readable.push (_stream_readable.js:212:10)
    at TCP.onStreamRead (internal/stream_base_commons.js:186:23)
    at Protocol._enqueue (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/protocol/Protocol.js:144:48)
    at Connection.query (/var/www/ghost/versions/3.32.2/node_modules/mysql/lib/Connection.js:198:25)
    at /var/www/ghost/versions/3.32.2/node_modules/knex/lib/dialects/mysql/index.js:135:18
    at Promise._execute (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/debuggability.js:384:9)
    at Promise._resolveFromExecutor (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/promise.js:518:18)
    at new Promise (/var/www/ghost/versions/3.32.2/node_modules/bluebird/js/release/promise.js:103:10)
    at Client_MySQL._query (/var/www/ghost/versions/3.32.2/node_modules/knex/lib/dialects/mysql/index.js:129:12)
    at Client_MySQL.query (/var/www/ghost/versions/3.32.2/node_modules/knex/lib/client.js:169:17)
    at /var/www/ghost/versions/3.32.2/node_modules/knex/lib/transaction.js:321:24
    at Client_MySQL.trxClient.query (/var/www/ghost/versions/3.32.2/node_modules/knex/lib/transaction.js:316:12)
    at Runner.query (/var/www/ghost/versions/3.32.2/node_modules/knex/lib/runner.js:151:36)
    at /var/www/ghost/versions/3.32.2/node_modules/knex/lib/runner.js:40:23
    at /var/www/ghost/versions/3.32.2/node_modules/knex/lib/runner.js:277:24
[2020-10-18 03:48:13] ERROR "POST /ghost/api/v3/admin/session" 500 10ms
level: critical
[2020-10-18 03:52:59] INFO "GET /" 301 1ms
[2020-10-18 03:56:45] INFO "GET /ghost/" 200 3ms
[2020-10-18 03:56:46] ERROR "GET /ghost/api/v3/admin/users/me/?include=roles" 403 3ms
level: normal
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
[2020-10-18 03:56:46] INFO "GET /ghost/api/v3/admin/site/" 200 1ms
[2020-10-18 03:56:46] INFO "GET /ghost/api/v3/admin/authentication/setup/" 200 9ms
[2020-10-18 03:56:51] ERROR "POST /ghost/api/v3/admin/session" 500 10ms
level: critical
— End of Log —
@Dale_K_M_Tan Hello. I’m facing same issue. Did you find any solution about that, if yes can you please help me?
@dibran.dev please start a new help topic and include the full details mentioned in the topic template. The previous poster is using a very old version of Ghost and didn’t share any debugging details.
