I have been trying for like a month to upgrade to anything and everything from v6.28. I’ve been getting the same error no matter what version I try to update to. I use the ghost cli on Debian 12, Linux and it always kicks back with this in the log:
OS: Debian GNU/Linux, v12
Node Version: v22.13.1
Ghost Version: 6.28.0
Ghost-CLI Version: 1.29.2
Environment: production
Command: ‘ghost update’
Message: Command failed: pnpm install --prod --reporter=append-only
/usr/local/lib/node_modules/corepack/dist/lib/corepack.cjs:21535
if (key == null || signature == null) throw new Error(Cannot find matching keyid: ${JSON.stringify({ signatures, keys })});
Error: Cannot find matching keyid: {“signatures”:[{“sig”:"MEUCIQD8aGiiEVFDqpcIAux49JR5tnWvSERz+izseguKrlwD9QIgLHoqYNaMcTbnF5/3SoV+zTMvNkwT9dPwYc2jRTi>
at verifySignature (/usr/local/lib/node_modules/corepack/dist/lib/corepack.cjs:21535:47)
at fetchLatestStableVersion (/usr/local/lib/node_modules/corepack/dist/lib/corepack.cjs:21553:5)
at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
at async fetchLatestStableVersion2 (/usr/local/lib/node_modules/corepack/dist/lib/corepack.cjs:21672:14)
at async Engine.getDefaultVersion (/usr/local/lib/node_modules/corepack/dist/lib/corepack.cjs:22298:23)
at async Engine.executePackageManagerRequest (/usr/local/lib/node_modules/corepack/dist/lib/corepack.cjs:22396:47)
at async Object.runMain (/usr/local/lib/node_modules/corepack/dist/lib/corepack.cjs:23102:5)
Node.js v22.13.1
Exit code: 1
Please, someone tell me what I’m missing.
