Hi all, running on https://hooshmand.net.
I think I may have a problem with updating ghost-cli. I’m on 1.14.1 and trying to get to 1.17.3.
I’ve updated nvm, run the npm command to update ghost-cli, and set the current system version of node to 14.17.6 which should be supported per Supported node versions for self-hosted installs of Ghost.
But I get this error on a ghost update, and also get it when I use force.
✖ Checking system Node.js version
Message: The version of Node.js you are using is not supported.
Supported: ^10.13.0 || ^12.10.0
Installed: 14.17.6
I also get the error
You are running an outdated version of Ghost-CLI.
It is recommended that you upgrade before continuing.
Run `npm install -g ghost-cli@latest` to upgrade.
BUT I have run that command multiple times, and it always says it updates one package. (ghost-cli@1.17.3), and then I get the same error and ghost --version still reports 1.14.1.
Any hints as to how to update?
Searched other threads and haven’t found anything.
