Upgrade not working
-Site: https://ourtwocentstravel.com
-OS: Ubuntu v22.04.5 LTS
-Node Version: v18.20.4
-Ghost Version: 5.96.0
-Ghost-CLI Version: 1.26.1
-Database Version: mysql 8.0.39-0ubuntu0.22.04.1
I did a ghost-cli upgrade and the output said a new version of npm was available.
sudo npm install ghost-cli@latest
sudo npm install -g npm@10.9.0
I then changed user to ghost-mgr and tried to update ghost using ghost update and it failed. Some permissions had gotten messed up. I ran ghost doctor and followed the recommendations to clean up permissions until it ran clean and tried to update again. The update failed. Output below:
ghost-mgr@ourtwocentstravel:/var/www/ghost$ ghost update
https://careers.ghost.org
+ sudo systemctl is-active ghost_ourtwocentstravel-com
✔ Checking system Node.js version - found v18.20.4
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking for available migrations
# 5.96.2
* 🐛 Fixed missing incoming recommendations (#21317) - Sag
View the changelog for full details: https://github.com/tryghost/ghost/compare/v5.96.1...v5.96.2
✔ Fetched release notes
✖ Downloading and updating Ghost to v5.96.2
A ProcessError occurred.
warning ../../package.json: No license field
warning ghost@5.96.2: The engine "cli" appears to be invalid.
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.29.1"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.29.4"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.1"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.27.0"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.4"
warning Resolution field "moment-timezone@0.5.45" is incompatible with requested version "moment-timezone@0.5.34"
warning Resolution field "jackspeak@2.1.1" is incompatible with requested version "jackspeak@^3.1.2"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.29.3"
warning Resolution field "@tryghost/errors@1.3.5" is incompatible with requested version "@tryghost/errors@^1.3.6"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.27.0"
warning Resolution field "@tryghost/errors@1.3.5" is incompatible with requested version "@tryghost/errors@1.3.1"
warning Resolution field "@tryghost/logging@2.4.18" is incompatible with requested version "@tryghost/logging@2.4.10"
warning lru.min@1.1.1: The engine "bun" appears to be invalid.
warning lru.min@1.1.1: The engine "deno" appears to be invalid.
warning " > bookshelf@1.2.0" has incorrect peer dependency "knex@>=0.15.0 <0.22.0".
error /var/www/ghost/versions/5.96.2/node_modules/re2: Command failed.
Exit code: 1
Command: install-from-cache --artifact build/Release/re2.node --host-var RE2_DOWNLOAD_MIRROR --skip-path-var RE2_DOWNLOAD_SKIP_PATH --skip-ver-var RE2_DOWNLOAD_SKIP_VER || node-gyp -j max rebuild
Arguments:
Directory: /var/www/ghost/versions/5.96.2/node_modules/re2
Output:
Trying https://github.com/uhop/node-re2/releases/download/1.21.3/linux-x64-108.br ...
Writing to build/Release/re2.node ...
The verification has failed: building from sources ...
Building locally ...
/bin/sh: 1: npm: Permission denied
node:internal/process/promises:288
            triggerUncaughtException(err, true /* fromPromise */);
[UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason "127".] {
  code: 'ERR_UNHANDLED_REJECTION'
Node.js v18.20.4
gyp info it worked if it ends with ok
gyp info using node-gyp@10.1.0
gyp info using node@18.20.4 | linux | x64
gyp info find Python using Python version 3.10.12 found at "/usr/bin/python3"
gyp info spawn /usr/bin/python3
gyp info spawn args [
gyp info spawn args '/var/www/ghost/versions/5.96.2/node_modules/re2/node_modules/node-gyp/gyp/gyp_main.py',
gyp info spawn args 'binding.gyp',
gyp info spawn args '-f',
gyp info spawn args 'make',
gyp info spawn args '-I',
gyp info spawn args '/var/www/ghost/versions/5.96.2/node_modules/re2/build/config.gypi',
gyp info spawn args '/var/www/ghost/versions/5.96.2/node_modules/re2/node_modules/node-gyp/addon.gypi',
gyp info spawn args '/home/ghost-mgr/.cache/node-gyp/18.20.4/include/node/common.gypi',
gyp info spawn args '-Dlibrary=shared_library',
gyp info spawn args '-Dvisibility=default',
gyp info spawn args '-Dnode_root_dir=/home/ghost-mgr/.cache/node-gyp/18.20.4',
gyp info spawn args '-Dnode_gyp_dir=/var/www/ghost/versions/5.96.2/node_modules/re2/node_modules/node-gyp',
gyp info spawn args '-Dnode_lib_file=/home/ghost-mgr/.cache/node-gyp/18.20.4/<(target_arch)/node.lib',
gyp info spawn args '-Dmodule_root_dir=/var/www/ghost/versions/5.96.2/node_modules/re2',
gyp info spawn args '-Dnode_engine=v8',
gyp info spawn args '--depth=.',
gyp info spawn args '--no-parallel',
gyp info spawn args '--generator-output',
gyp info spawn args 'build',
gyp info spawn args '-Goutput_dir=.'
gyp info spawn args ]
gyp info spawn make
gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build', '--jobs', 1 ]
make: Entering directory '/var/www/ghost/versions/5.96.2/node_modules/re2/build'
  CXX(target) Release/obj.target/re2/lib/addon.o
make: g++: Permission denied
make: *** [re2.target.mk:246: Release/obj.target/re2/lib/addon.o] Error 127
make: Leaving directory '/var/www/ghost/versions/5.96.2/node_modules/re2/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.<anonymous> (/var/www/ghost/versions/5.96.2/node_modules/re2/node_modules/node-gyp/lib/build.js:209:23)
gyp ERR! System Linux 5.15.0-122-generic
gyp ERR! command "/usr/bin/node" "/var/www/ghost/versions/5.96.2/node_modules/re2/node_modules/.bin/node-gyp" "-j" "max" "rebuild"
gyp ERR! cwd /var/www/ghost/versions/5.96.2/node_modules/re2
gyp ERR! node -v v18.20.4
gyp ERR! node-gyp -v v10.1.0
gyp ERR! not ok
yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
Exit code: 1
ghost doctor now runs clean, but ghost doesn’t seem to be recognizing my cli.
Full log from an installation attempt is available. Please let me know if you’d like me to add it into the post.
Thanks for any assistance!
Forgot to mention, this is a Digital Ocean build. Also, contents of last update attempt log are below:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following package was automatically installed and is no longer required:
  libnftables1
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
  python3-cliapp python3-markdown python3-pygments python3-ttystatus
Suggested packages:
  python3-xdg python-markdown-doc python-pygments-doc ttf-bitstream-vera
The following NEW packages will be installed:
  cmdtest python3-cliapp python3-markdown python3-pygments python3-ttystatus
0 upgraded, 5 newly installed, 0 to remove and 1 not upgraded.
Need to get 899 kB of archives.
After this operation, 4875 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://mirrors.digitalocean.com/ubuntu jammy/universe amd64 python3-cliapp all 1.20180812.1-4 [44.5 kB]
Get:2 http://mirrors.digitalocean.com/ubuntu jammy/main amd64 python3-markdown all 3.3.6-1 [68.5 kB]
Get:3 http://mirrors.digitalocean.com/ubuntu jammy/universe amd64 python3-ttystatus all 0.38-4 [14.7 kB]
Get:4 http://mirrors.digitalocean.com/ubuntu jammy/universe amd64 cmdtest all 0.32.14.gcdfe14e-2 [21.9 kB]
Get:5 http://mirrors.digitalocean.com/ubuntu jammy/main amd64 python3-pygments all 2.11.2+dfsg-2 [750 kB]
Fetched 899 kB in 6s (143 kB/s)
Selecting previously unselected package python3-cliapp.
(Reading database ... 125926 files and directories currently installed.)
Preparing to unpack .../python3-cliapp_1.20180812.1-4_all.deb ...
Unpacking python3-cliapp (1.20180812.1-4) ...
Selecting previously unselected package python3-markdown.
Preparing to unpack .../python3-markdown_3.3.6-1_all.deb ...
Unpacking python3-markdown (3.3.6-1) ...
Selecting previously unselected package python3-ttystatus.
Preparing to unpack .../python3-ttystatus_0.38-4_all.deb ...
Unpacking python3-ttystatus (0.38-4) ...
Selecting previously unselected package cmdtest.
Preparing to unpack .../cmdtest_0.32.14.gcdfe14e-2_all.deb ...
Unpacking cmdtest (0.32.14.gcdfe14e-2) ...
Selecting previously unselected package python3-pygments.
Preparing to unpack .../python3-pygments_2.11.2+dfsg-2_all.deb ...
Unpacking python3-pygments (2.11.2+dfsg-2) ...
Setting up python3-ttystatus (0.38-4) ...
Setting up python3-cliapp (1.20180812.1-4) ...
Setting up python3-pygments (2.11.2+dfsg-2) ...
Setting up python3-markdown (3.3.6-1) ...
Setting up cmdtest (0.32.14.gcdfe14e-2) ...
Processing triggers for man-db (2.10.2-1) ...
Scanning processes...
Scanning linux images...
Running kernel seems to be up-to-date.
No services need to be restarted.
No containers need to be restarted.
No user sessions are running outdated binaries.
No VM guests are running outdated hypervisor (qemu) binaries on this host.
tedl@ourtwocentstravel:~$ sudo -i -u ghost-mgr
ghost-mgr@ourtwocentstravel:~$ cd /var/www/ghost
ghost-mgr@ourtwocentstravel:/var/www/ghost$ export GITLAB_AUTH_TOKEN=
ghost-mgr@ourtwocentstravel:/var/www/ghost$ yarn cache clean
00h00m00s 0/0: : ERROR: [Errno 2] No such file or directory: 'cache'
# 5.96.2
Exit code: 1
Arguments:
Output:
Node.js v18.20.4
gyp info spawn make
gyp ERR! System Linux 5.15.0-124-generic
gyp ERR! not ok
Exit code: 1
    OS: Ubuntu, v22.04.5 LTS
    Environment: production
    Command: 'ghost update'
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2024-10-17T18_51_30_401Z.log
ghost-mgr@ourtwocentstravel:/var/www/ghost$ yarn --version
0.32+git
ghost-mgr@ourtwocentstravel:/var/www/ghost$ yarn cache list
ghost-mgr@ourtwocentstravel:/var/www/ghost$ exit
logout
tedl@ourtwocentstravel:~$ sudo yarn cache clean
tedl@ourtwocentstravel:~$ yarn cache list
tedl@ourtwocentstravel:~$ sudo yarn cache list
[sudo] password for tedl:
ghost-mgr@ourtwocentstravel:~$ ls
config.production.json.mailgun-working  config.production.json.new-mailgun-not-working  config.production.json.orig
ghost-mgr@ourtwocentstravel:~$ ll
total 80
drwxr-x--- 7 ghost-mgr ghost-mgr  4096 Oct 17 16:07 ./
drwxr-xr-x 4 root      root       4096 Aug 25 23:02 ../
-rw------- 1 ghost-mgr ghost-mgr  4029 Oct 17 18:53 .bash_history
-rw-r--r-- 1 ghost-mgr ghost-mgr   220 Jan  6  2022 .bash_logout
-rw-r--r-- 1 ghost-mgr ghost-mgr  3771 Jan  6  2022 .bashrc
drwxrwxr-x 4 ghost-mgr ghost-mgr  4096 Oct  6 18:38 .cache/
-rw-r--r-- 1 ghost-mgr ghost-mgr     0 Aug  7 12:21 .cloud-locale-test.skip
drwxr-x--- 3 ghost-mgr ghost-mgr  4096 Oct 17 15:27 .config/
drwxrwxr-x 3 ghost-mgr ghost-mgr  4096 Oct 17 15:20 .ghost/
-rw------- 1 ghost-mgr ghost-mgr    20 Oct 17 16:07 .lesshst
-rw------- 1 ghost-mgr ghost-mgr    34 Aug 28 20:21 .mysql_history
drwxrwxr-x 5 ghost-mgr ghost-mgr  4096 Aug 25 22:43 .npm/
-rw-r--r-- 1 ghost-mgr ghost-mgr   807 Jan  6  2022 .profile
-rw-r--r-- 1 ghost-mgr ghost-mgr     0 Aug  7 12:25 .sudo_as_admin_successful
-rw------- 1 ghost-mgr ghost-mgr 12715 Sep  2 13:53 .viminfo
drwxrwxr-x 3 ghost-mgr ghost-mgr  4096 Aug 25 22:43 .yarn/
-rw-rw-r-- 1 ghost-mgr ghost-mgr   867 Sep  2 13:29 config.production.json.mailgun-working
-rw-rw-r-- 1 ghost-mgr ghost-mgr   853 Sep  2 03:01 config.production.json.new-mailgun-not-working
-rw-rw-r-- 1 ghost-mgr ghost-mgr   533 Sep  1 20:26 config.production.json.orig
ghost-mgr@ourtwocentstravel:~$ cd .yarn/
ghost-mgr@ourtwocentstravel:~/.yarn$ ls
bin
ghost-mgr@ourtwocentstravel:~/.yarn$ cd
ghost-mgr@ourtwocentstravel:~$ cd .ghost
ghost-mgr@ourtwocentstravel:~/.ghost$ ls
config  logs
ghost-mgr@ourtwocentstravel:~/.ghost$ cd logs/
ghost-mgr@ourtwocentstravel:~/.ghost/logs$ ls
ghost-cli-debug-2024-10-17T15_20_46_875Z.log  ghost-cli-debug-2024-10-17T16_18_50_957Z.log  ghost-cli-debug-2024-10-17T18_51_30_401Z.log
ghost-cli-debug-2024-10-17T15_27_19_456Z.log  ghost-cli-debug-2024-10-17T16_26_37_944Z.log
ghost-cli-debug-2024-10-17T15_29_08_374Z.log  ghost-cli-debug-2024-10-17T18_45_50_912Z.log
ghost-mgr@ourtwocentstravel:~/.ghost/logs$ ll
total 88
drwxr-x--- 2 ghost-mgr ghost-mgr  4096 Oct 17 18:51 ./
drwxrwxr-x 3 ghost-mgr ghost-mgr  4096 Oct 17 15:20 ../
-rw-r----- 1 ghost-mgr ghost-mgr  1085 Oct 17 15:20 ghost-cli-debug-2024-10-17T15_20_46_875Z.log
-rw-r----- 1 ghost-mgr ghost-mgr 12643 Oct 17 15:27 ghost-cli-debug-2024-10-17T15_27_19_456Z.log
-rw-r----- 1 ghost-mgr ghost-mgr 11877 Oct 17 15:29 ghost-cli-debug-2024-10-17T15_29_08_374Z.log
-rw-r----- 1 ghost-mgr ghost-mgr 11877 Oct 17 16:18 ghost-cli-debug-2024-10-17T16_18_50_957Z.log
-rw-r----- 1 ghost-mgr ghost-mgr 11877 Oct 17 16:26 ghost-cli-debug-2024-10-17T16_26_37_944Z.log
-rw-r----- 1 ghost-mgr ghost-mgr 11877 Oct 17 18:45 ghost-cli-debug-2024-10-17T18_45_50_912Z.log
-rw-r----- 1 ghost-mgr ghost-mgr 11877 Oct 17 18:51 ghost-cli-debug-2024-10-17T18_51_30_401Z.log
ghost-mgr@ourtwocentstravel:~/.ghost/logs$ less ghost-cli-debug-2024-10-17T18_51_30_401Z.log
Exit code: 1
Arguments:
Output:
Node.js v18.20.4
gyp info spawn make
gyp ERR! not ok
Exit code: 1
--------------- stdout ---------------
--------------- stderr ---------------
Exit code: 1
Arguments:
Output:
Node.js v18.20.4
gyp info spawn make
gyp ERR! not ok
I put quite a bit of time into this but was unable to figure it out. Restored from previous backup and got it working. OK to close.
