My ghost install randomly broke after upgrading… no matter what ghost command I run I get this error:
[poolghost@darkice public_html]$ ghost restart
/usr/lib/node_modules/ghost-cli/lib/command.js:108
static async _run(commandName, argv = {}, extensions) {
SyntaxError: Unexpected identifier
at createScript (vm.js:56:10)
at Object.runInThisContext (vm.js:97:10)
at Module._compile (module.js:549:28)
at Object.Module._extensions..js (module.js:586:10)
at Module.load (module.js:494:32)
at tryModuleLoad (module.js:453:12)
at Function.Module._load (module.js:445:3)
at Module.require (module.js:504:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/lib/node_modules/ghost-cli/lib/bootstrap.js:6:17)
[poolghost@darkice public_html]$ ghost help
I am running CentOS 3.10.0-957.21.3.el7.x86_64
Please advise how to fix. I am not sure how to check what version I am running since all Ghost commands are now broken…
[poolghost@darkice public_html]$ node -v
v6.17.1
