This release includes improvements to typography, vertical rhythm, and visual hierarchy, a redesigned footer signup section, post tags in the post footer, and updated documentation.
I bought Verse and downloaded the folder verse-v1.3.0. The documentation says to install the theme via Ghost Settings – Theme – Change Theme and then upload the theme ZIP file and activate Verse. But the downloaded folder doesn’t contain anything recognisable as the Verse theme and the instructions provide no further information. Can anyone tell me what exactly I’m supposed to be looking for?
I did try uploading the downloaded folder as a whole, but that’s not possible, because it’s a folder rather than a file with the appropriate extension.
Any chance your computer unzipped it for you, and you need to rezip it? I’ve seen enough Macs configured that way. You should have received a .zip file. If you’ve got a folder, you need to get your browser not to unzip downloads, or just zip the folder up again.
