Good Morning,
I’m trying to understand the operation of the {{visibility}} handlebar, but the truth is, as much as I see examples in the forum, I can’t understand the casuistry related to this handlebar.
Specifically, I am trying to use it to differentiate: public, members and paid, as part of a class; a fairly common and habitual use.
The fact is that if I put in isolation: class="{{visibility}}" no result is shown.
Is it possible that the handlebar is conditioned to something?
Specifically, the use case is this:
<header class="site-head {{visibility}}">
Through which, I would like to identify two different states, to change their background color.
In said header, the only logic that I apply on the states is in navigation:
{{#if @member}}
{{navigation type="secondary"}}
{{else}}
{{navigation}}
{{/if}}
From what I understand, that the header does not obtain that differential logic and therefore it is possible that it is the reason why it does not give me any results.
At the moment, I am applying a workable solution to the problem:
<header class="site-head {{#if @member}}member{{else}}public{{/if}}">
But I would be very grateful if any of you could help me understand and understand more efficiently the use of {{visibility}}; especially to understand their dependence.
Thank you all for your help.
A hug.
