Wave theme not showing like demo
Hello I just switched to Ghost Pro (from self hosted) and just installed the wave theme.
However, the homepage is not showing up in the same format as the demo. The functionality where you can play the podcast on the homepage is missing. Icons and posts are showing inline, 3 to a column instead of block items 1 to a row. (amongst other differences)
Has anyone else faced this issue? Any help would be amazing.
Here’s the demo and here’s my link where it’s installed.
:wave: The wave theme uses a bit of a trick to made the podcast player work, you paste the episode URL into the “facebook description” field - and then the theme uses that to make the player work! It’s a bit of a weird quirk, but it does work! :)
Instructions here:
Thanks, John. I appreciate the help. :sparkles:
