Website is not working after installation (maybe NGINX problem)
Hi my website is not working (404 error) after installation. I think it is something related to nginx.
ghost doctor:
:heavy_check_mark: Checking system Node.js version - found v20.18.1
:heavy_check_mark: Checking logged in user
:heavy_check_mark: Ensuring user is not logged in as ghost user
:heavy_check_mark: Checking if logged in user is directory owner
:heavy_check_mark: Checking system compatibility
:heavy_check_mark: Checking for a MySQL installation
  • sudo systemctl is-active ghost_www-elektrojazdenie-sk
    Instance is currently running
    :information_source: Validating config [skipped]
    :heavy_check_mark: Checking folder permissions
    :heavy_check_mark: Checking file permissions
    :heavy_check_mark: Checking content folder ownership
    :heavy_check_mark: Checking binary dependencies
    :heavy_check_mark: Checking free space
    :heavy_check_mark: Checking systemd unit file
    :heavy_check_mark: Checking systemd node version - found v20.18.1
Ghost setup ssl:
  • sudo /etc/letsencrypt/acme.sh --upgrade --home /etc/letsencrypt
  • sudo /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --server letsencrypt --domain www.elektrojazdenie.sk --webroot /var/www/elektrojazdenie/system/nginx-root --reloadcmd “nginx -s reload” --accountemail info@elektrojazdenie.sk --keylength 2048
    :heavy_multiplication_x: Setting up SSL
    One or more errors occurred.
  1. ProcessError
Message: Command failed: /bin/sh -c sudo -S -p ‘#node-sudo-passwd#’ /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --server letsencrypt --domain www.elektrojazdenie.sk --webroot /var/www/elektrojazdenie/system/nginx-root --reloadcmd “nginx -s reload” --accountemail info@elektrojazdenie.sk --keylength 2048
[Tue Dec 31 14:42:09 UTC 2024] www.elektrojazdenie.sk: Invalid status. Verification error details: 141.144.236.165: Fetching http://www.elektrojazdenie.sk/.well-known/acme-challenge/PT70PMI-L8aBpclh0GKcFinS3KudUV0JaS5P1nNZ1Q4: Error getting validation data
[Tue Dec 31 14:42:09 UTC 2024] Please add ‘–debug’ or ‘–log’ to see more information.
[Tue Dec 31 14:42:09 UTC 2024] See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub
[Tue Dec 31 14:42:04 UTC 2024] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Tue Dec 31 14:42:04 UTC 2024] Single domain=‘www.elektrojazdenie.sk’
[Tue Dec 31 14:42:05 UTC 2024] Getting webroot for domain=‘www.elektrojazdenie.sk’
[Tue Dec 31 14:42:05 UTC 2024] Verifying: www.elektrojazdenie.sk
[Tue Dec 31 14:42:06 UTC 2024] Pending. The CA is processing your order, please wait. (1/30)
Exit code: 1
OS: Ubuntu, v22.04.5 LTS
Node Version: v20.18.1
Ghost Version: 5.105.0
Ghost-CLI Version: 1.26.1
Environment: production
Command: ‘ghost setup ssl’
/etc/nginx/sites-available - file www.elektrojazdenie.sk.conf:
map $status $header_content_type_options {
204 “”;
default “nosniff”;
server {
listen 80;
listen [::]:80;
server_name www.elektrojazdenie.sk;
root /var/www/elektrojazdenie/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
location / {
    add_header X-Content-Type-Options $header_content_type_options;
location ~ /.well-known {
    allow all;
client_max_body_size 50m;
NGINX status:
sudo systemctl status nginx
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2024-12-31 14:02:24 UTC; 46min ago
Docs: man:nginx(8)
Process: 731 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 829 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 840 (nginx)
Tasks: 3 (limit: 14232)
Memory: 15.2M
CPU: 74ms
CGroup: /system.slice/nginx.service
├─ 840 “nginx: master process /usr/sbin/nginx -g daemon on; master_process on;”
├─4328 “nginx: worker process” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” “” "> └─4329 “nginx: worker process” “” “” “” “” “” “” “” “” “” “”
GHOST LS>
Name │ Location │ Version │ Status │ URL │ Port │ Process Manager │
│ www-elektrojazdenie-sk │ /var/www/elektrojazdenie │ 5.105.0 │ running (production) │ https://www.elektrojazdenie.sk │ 2368 │ systemd │
Many thanks for help.
BR,
Try install SSL-Certificate manually:
acme.sh  --issue  -d www.elektrojazdenie.sk --nginx
Or use Certbot
Thanks, but is it not working.
BUT, I already found solution as I found that all Oracle images have IPTABLES enabled with some rules already in place.
I allowed port 80 in iptables and it is working.
