Website not working after installation
Issue Summary
Hi all!
I’ve reinstalled ghost several times today. I can’t figure out what is the reason, but the installation completes successfully, but the site itself does not open. The domain is directed to the IP of the server.
Server IP: 185.248.102.110
SIte: litwin.pro
Please help me to solve the problem…
Steps to Reproduce
  1. Repeated removal and reinstallation
  2. Change host and port ( https://skr.sh/sIzkaVa0b48 )
Setup information
Ghost Version
5.39.0
Node.js Version
  • v16.19.1*
How did you install Ghost?
Installation according to instructions ghost
Ubuntu, v22.04.2 LTS
Database type
mysqld 8.0.32
Browser & OS version
Chrome.
nginx config
server {
    listen 80;
    listen [::]:80;
    server_name litwin.pro;
    root /var/www/litwin.pro/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
    location / {
    location ~ /.well-known {
        allow all;
    client_max_body_size 50m;
For starters, it looks like SSL (https) isn’t correctly configured. However, I can’t connect to your site.
Please confirm that Ghost is running without error, and try ghost setup ssl (note that too many attempts will prevent certificates being issued.)
Thank you very much!
The “ghost setup ssl” command helped. I saw in the logs that the problem is with crontab. In the end, I reinstalled everything and it worked!
