Hey Gang!
I’m having issues integrating MailChimp and my Ghost CMS Members.
Ideally, I would like the user to hit subscribe as a member on my Ghost website and the email adds to my existing MailChimp audience.
On the Zapier integration, I cannot seem to select the new member’s email. The only option that’s available is my own account email.
Please see reference img below:
Based on the image, it looks like all the variables are subscriber data - fields like comped and geolocation are limited to members, not staff. Can you try using the email field and test what happens with an alias (e.g. subscribe with saythepodcast.member@gmail.com)?
We do have Mailchimp Zapier integrations over here @Saysay_Dalisay :
Might save you the work, or a good reference point.
Thanks for the reply David!
Hope you had a great Easter
The Zap integrations seem to be using subscriber which is deprecated. Is this correct?
vikaspotluri123:
Based on the image, it looks like all the variables are subscriber data - fields like comped and geolocation are limited to members, not staff. Can you try using the email field and test what happens with an alias (e.g. subscribe with saythepodcast.member@gmail.com )?
You’re 100% right! The “saythepodcast@gmail.com ” email is greyed out which probably means that’s how it looks as an example.
Everything working great!
Regards
