New blog post:
The first part is all stuff you should already know, because you read the Ghost manual in great detail, right? Right? Well, anyway, if you didn’t know you can filter your posts view in the admin dashboard, you might learn something new.
And then the second part is a trick for filtering on multiple tags or authors. Need to see posts with both of two tags? We can do that…
