403 Forbidden error at my domain
I’m new Ghost user. Pleased meet you guys.
I trying start Ghost. Seems I sucessed installed Ghost at my vps server but when I open mywebsite.com/g2 which I installed it. 403 Forbidden error show up.
What’s your URL? This is the easiest way for others to debug your issue
mywebsite.com/g2
Ghost-CLI version: 1.16.3
Ghost version: 4.3.3
What configuration?
OS - Centos 7.9
RAM - 2 GB
Nginx 1.19.10
What browser?
Firefox and WaterFox
ghost doctor shows no error
I installed Ghost in /var/www/mywebsite.com/html/g2
I installed cerbot SSL. and I can display index.html file at https://mywebsite.com/
Here is my /var/www/html/g2/config.development
Could you teach me what is wrong please?
“url”: “h t t p s : / / m y w e b i s i t e .com/g2”,
“server”: {
“port”: 443,
“database”: {
“client”: “sqlite3”,
“connection”: {
“filename”: “/var/www/html/g2/content/data/ghost-local.db”
“mail”: {
“transport”: “Direct”
“logging”: {
“transports”: [
“file”,
“stdout”
“process”: “local”,
“paths”: {
“contentPath”: “/var/www/html/g2/content”
And Here is /etc/nginx/nginx.conf
user nginx;
worker_processes 1;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                  '$status $body_bytes_sent "$http_referer" '
                  '"$http_user_agent" "$http_x_forwarded_for"';
access_log  /var/log/nginx/access.log  main;
sendfile        on;
#tcp_nopush     on;
keepalive_timeout  65;
#gzip  on;
include /etc/nginx/conf.d/*.conf;
server {
listen 443 ssl;
server_name m y w e b i s i t e . com;
charset UTF-8;
ssl_certificate /etc/letsencrypt/live/mywebisite.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/mywebisite.com/privkey.pem;
root /var/www/html;
location / {
index index.php index.html index.htm;
location ^~ /blog {
location ~ .php$ {
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
include fastcgi_params;
