403 Forbidden Error
  • What’s your URL? This is the easiest way for others to debug your issue
    https://hostitor.com/blog
    Ghost-CLI version: 1.14.1
    Ghost version: 3.29.1
  • What configuration?
    OS - Ubuntu 18.04
    RAM - 1 GB
    Nginx
  • What browser?
    Any
    ghost doctor shows no error
    I installed Ghost in /var/www/website.com/html/blog/ghost
    Since I already had Nginx installed, I choose not to install it during Ghost installation. There was no error while installing the Ghost but it doesn’t seem to be working as you can see hostitor.com/blog shows 403 Forbidden Error
Seems you have to configure nginx server block for your blog
Edit your domains server block … by default it sits at /etc/nginx/sites-available/yourdomain.com
& add the following codes between the server block
 location ^~ /blog {
restart nginx sudo systemctl restart nginx
& your blog will work at https://hostitor.com/blog
Now it is working. Thank you!
You are welcome…Cheers!
