From searching the forum, this appears to be related to the new announcements feature, which I have not tried to implement for our site. I am assuming there is some code being inserted into my site to support this feature, but I have not done anything in the settings for this site for years. While it does not seem to affect my site in any way, I would like to avoid the notifications I regularly receive that I have a broken link for my site and then check the report only to find it is this every time.
OK, so how do I remove the link? Theoretically, broken links can affect a site’s Google ranking. I need to have the site checked for broken links because virtually all the posts have a link to an article somewhere else, and I waste time accessing the report only to discover that it is, once again, this webmentions link. Should I submit a bug report?
It seems that a reference to the URL appears in ghost_head. You could re-create a template so that it contains all the other thing that ghost_head does except this mention
BUT
I’ve read some related source code in Ghost and the spec for webmentions and it appears that Ghost has implemented the spec correctly. Ghost is including a structure like this in the header:
The spec appears to say that only POST requests should be sent to this URL, but it appears that your link check is following the URL and sending a GET request to it, which Ghost doesn’t need to support.
If I’m reading things correctly, this is a bug in how the link checker handles linked to webmentions specifically.
