422 Unprocessable Entity Error when uploading a theme
Hey Everyone :wave:
Hope you are all well!
I am uploading a theme where I have made marginal changes to the template logic. I have also made some style changes.
I downloaded the casper theme from my server and then edited it, followed the guide on using yarn zip to run gulp. I have also used the yarn test command to validate, there were no errors.
Output from yarn test
Checking theme compatibility...
✓ Your theme is compatible with Ghost 3.x
Recommendations
- Recommendation: The output of {{id}} changed in Ghost v1.0.0, you may need to use {{comment_id}} instead.
Files: post.hbs
I am getting the following error back when uploading the theme:
1. {message: "Failed to read zip file", context: "dev.zip", type: "ValidationError",…}
  1. code: null
  2. context: "dev.zip"
  3. details: "EACCES: permission denied, mkdir '/tmp/4d8b9927-175f-413b-a432-17619489990a/assets/built/'"
  4. help: "Your zip file might be corrupted, try unzipping and zipping again."
  5. id: "22dd3ce0-bb9f-11ea-8882-7f108c728b8c"
  6. message: "Failed to read zip file"
  7. property: null
  8. type: "ValidationError"
And the form data in the request is as follows:
------WebKitFormBoundaryrjL6eftelraznaFZ
Content-Disposition: form-data; name="file"; filename="dev.zip"
Content-Type: application/x-zip-compressed
------WebKitFormBoundaryrjL6eftelraznaFZ--
Are you on Windows using gulp-zip < 5.0.2, if so, upgrading gulp-zip might fix it.
Else, how did you install Ghost?
Hey Hannah, thanks for the reply.
It appears you were right about the version number :grin: .I have upgraded it and seems to work fine. Thank you for your help!
