This was just after a Node 16->18 upgrade that appeared successful.
It appears there maybe a problem the “re2” dep being corrupt. Some key logs are:
error /sites/pea-pod.org/versions/5.75.1/node_modules/re2: Command failed.
Exit code: 7
Command: install-from-cache --artifact build/Release/re2.node --host-var RE2_DOWNLOAD_MIRROR --skip-path-var RE2_DOWNLOAD_SKIP_PATH --skip-ver-var RE2_DOWNLOAD_SKIP_VER || npm run rebuild
Arguments:
Directory: /sites/pea-pod.org/versions/5.75.1/node_modules/re2
Output:
Trying https://github.com/uhop/node-re2/releases/download/1.20.3/linux-x64-108.br ...
Writing to build/Release/re2.node ...
The verification has failed: building from sources ...
Maybe trying to bump the version of the re2 dep would help?
The install logs continue with a different error about New Relic “native-metrics” having a problem.
Building locally ...
/usr/lib/node_modules/npm/lib/cli.js:35
throw err
TypeError: Class extends value undefined is not a constructor or null
at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-minipass/lib/index.js:136:4)
at Module._compile (node:internal/modules/cjs/loader:1256:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
at Module.load (node:internal/modules/cjs/loader:1119:32)
at Module._load (node:internal/modules/cjs/loader:960:12)
at Module.require (node:internal/modules/cjs/loader:1143:19)
at require (node:internal/modules/cjs/helpers:121:18)
at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/cacache/lib/content/read.js:4:13)
Node.js v18.17.1
node:internal/process/promises:288
triggerUncaughtException(err, true /* fromPromise */);
[UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason "7".] {
code: 'ERR_UNHANDLED_REJECTION'
Node.js v18.17.1
throw err
Node.js v18.17.1
warning Error running install script for optional dependency: "/sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics: Command failed.
Exit code: 1
Command: node ./lib/pre-build.js install native_metrics
Arguments:
Directory: /sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics
Output:
Attempting install in native-metrics module. Please note that this is an
OPTIONAL dependency, and any resultant errors in this process will not
affect the general performance of the New Relic agent, but event loop and
garbage collection metrics will not be collected for the Node VMs page.
Download error: ENOENT: no such file or directory, open '/sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics/build/Release/_newrelic_native_metrics-10_0_0-native_metrics-108-linux-x64.node', falling back to build
> /usr/bin/node /sites/pea-pod.org/versions/5.75.1/node_modules/node-gyp/bin/node-gyp.js clean configure
gyp info it worked if it ends with ok
gyp info using node-gyp@8.4.1
gyp info using node@18.17.1 | linux | x64
gyp info find Python using Python version 3.8.10 found at \"/usr/bin/python3\"
gyp info spawn /usr/bin/python3
gyp info spawn args [
gyp info spawn args '/sites/pea-pod.org/versions/5.75.1/node_modules/node-gyp/gyp/gyp_main.py',
gyp info spawn args 'binding.gyp',
gyp info spawn args '-f',
gyp info spawn args 'make',
gyp info spawn args '-I',
gyp info spawn args '/sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics/build/config.gypi',
gyp info spawn args '/sites/pea-pod.org/versions/5.75.1/node_modules/node-gyp/addon.gypi',
gyp info spawn args '/home/mark/.cache/node-gyp/18.17.1/include/node/common.gypi',
gyp info spawn args '-Dlibrary=shared_library',
gyp info spawn args '-Dvisibility=default',
gyp info spawn args '-Dnode_root_dir=/home/mark/.cache/node-gyp/18.17.1',
gyp info spawn args '-Dnode_gyp_dir=/sites/pea-pod.org/versions/5.75.1/node_modules/node-gyp',
gyp info spawn args '-Dnode_lib_file=/home/mark/.cache/node-gyp/18.17.1/<(target_arch)/node.lib',
gyp info spawn args '-Dmodule_root_dir=/sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics',
gyp info spawn args '-Dnode_engine=v8',
gyp info spawn args '--depth=.',
gyp info spawn args '--no-parallel',
gyp info spawn args '--generator-output',
gyp info spawn args 'build',
gyp info spawn args '-Goutput_dir=.'
gyp info spawn args ]
gyp info ok
> /usr/bin/node /sites/pea-pod.org/versions/5.75.1/node_modules/node-gyp/bin/node-gyp.js build -j 1 native_metrics
gyp info spawn make
gyp info spawn args [ 'native_metrics', 'BUILDTYPE=Release', '-C', 'build', '--jobs', 1 ]
make: Entering directory '/sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics/build'
CXX(target) Release/obj.target/native_metrics/src/native_metrics.o
make: g++: Command not found
make: *** [native_metrics.target.mk:121: Release/obj.target/native_metrics/src/native_metrics.o] Error 127
make: Leaving directory '/sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/sites/pea-pod.org/versions/5.75.1/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (node:events:514:28)
gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:291:12)
gyp ERR! System Linux 6.2.9-x86_64-linode160
gyp ERR! command \"/usr/bin/node\" \"/sites/pea-pod.org/versions/5.75.1/node_modules/node-gyp/bin/node-gyp.js\" \"build\" \"-j\" \"1\" \"native_metrics\"
gyp ERR! cwd /sites/pea-pod.org/versions/5.75.1/node_modules/@newrelic/native-metrics
gyp ERR! node -v v18.17.1
gyp ERR! node-gyp -v v8.4.1
gyp ERR! not ok
Failed to execute native-metrics install: Command exited with non-zero code: 1
This is another recent issue about a New Relic native metrics problem, but on Windows 11:
