{{accent_color}} to "theme-color" meta tag
Hello!
I was trying to find a way to make the theme-color meta tag matches accent_color
<meta name="theme-color" content="#{{accent_color}}"/>
the problem is that theme-color can’t accept css var so I should pass a " {{}}" idk how to call it but…
in the {{ghost_head}} helper was the var --ghost-accent-color defined
so how can I pass the that value to theme-color tag
Thank you
Even though it’s not listed in the @site global variable docs, it should be possible to use {{@site.accent_color}}
I will try it, thank you!
I spent the last couple of hours trying to figure out how to do it and found a way too :)
document.querySelector('meta[name="theme-color"]').setAttribute("content", window.getComputedStyle(document.documentElement).getPropertyValue('--ghost-accent-color'));
Thanks for catching this!
I updated the docs to include a reference for the accent_color property:
