Is there a way to add a dateline to my news stories? I assume not having a dateline is part of the theme I’m using but maybe I can add it? My stories only come with a bracketed and vague “2 months ago” or “3 weeks ago.” I obviously know the date and time from the back end but I want readers to know the date stories were posted.
If you can edit the theme, that should be straightforward. Are you on a plan that lets you edit your theme? (Not a ‘Starter’ plan.)
Docs you’ll need:
You’re looking for the date helper, to change its configuration. Here’s how it works: Ghost Handlebars Theme Helpers: date
Here’s a tutorial for how to download the theme: Download and upload a Ghost theme
And how to edit it:
Developer help Hi Paul, You may find below info/steps useful-
Before starting, ensure:
- You are not on the Ghost Starter plan (must allow theme customization).
- You have access to download, edit, and upload themes.
- You have a code editor (like VS Code) installed.
Step-by-Step: Add a Dateline to News Stories
1. Download Your Theme
- Go to Ghost Admin → Settings → Design → Click Download current theme.
2. Unzip and Open in Code Editor
- Unzip the downloaded
.zipfile. - Open the folder in your code editor (e.g., VS Code).
3. Locate the Template File
- Open
post.hbs— this template controls the layout of individual stories.- If it doesn’t exist, check
default.hbsorpage.hbsas a fallback. - You might also find your content loop in
index.hbsorhome.hbs.
4. Insert or Update the Date Helper
Look for where the time or date is shown (or add this in a logical place like under the post title):
hbs
<time datetime="{{date published_at format="YYYY-MM-DD"}}">
{{date published_at format="DD MMMM YYYY"}}
</time>
This will display a date like 09 July 2025. You can adjust the format using Moment.js tokens.
5. Remove the Timeago Format (Optional)
If you currently see:
hbs
{{date published_at timeago="true"}}
Replace it with the full date helper above to show an absolute date instead of “x weeks ago.”
6. Repackage the Theme
- Zip the entire theme folder (select all files, not the folder itself).
- Make sure
package.jsonis in the root of the zip.
7. Upload the Updated Theme
- Go back to Ghost Admin → Settings → Design → Click Upload a theme.
- Upload your modified theme zip.
8. Preview and Publish
- Visit a news story on your site.
- You should now see a properly formatted date displayed clearly near the title or wherever you placed it.
