Running the latest version. I am wondering if anyone knows what file I should edit or if there’s a snippet available for adding additional subscription options to Ghost?
As of now, monthly and yearly is all there is. It would be nice if I (we) could add quarter and half year, giving the user additional options.
You’ll want to read the last paragraph of the changelog for 4.
If you’re still here and still reading, you might be wondering what’s next. That’s how these things usually go. You spend a couple of years baking a magnificent cake and you say “here is our cake, behold the icing in all its splendour, would you like some?” - and invariably the response is “what will be in the next cake”.
Fair enough.
The next cake is custom plans. Right now Ghost has monthly, yearly and complimentary plans built-in by default, but soon you will be able to define any plan you like with custom properties. Nice.
Ghost’s behavior on receiving a webhook about a new subscription is actually to attempt to create/update the user in Ghost. I don’t know what would happen if you set up a 3mo/6mo subscription in Stripe and provided a direct check-out link. I suspect /something/ would propagate back to Ghost. Odds of being able to manage it in Ghost aren’t super high, however, but Stripe does provide a pretty good customer portal you can turn on… might be worth the experiment!
