Adstxt file problem please help
I uploaded my ads.txt file to the root folder and its just redirecting to a 404 page. What can I do?
I think you need to take a copy of your theme, add this file to the root folder, re-zip, and then upload.
This is what I did and its not working. Seems that the Ghost platform does not read .txt as a file. Please help there must be another way that I can show this from my root folder so Google can crawl it.
I just tried this, and it works fine. Make sure you add the file to the theme’s root folder.
Since you’re getting a 404, double check folder used, and file permissions. I assume you can open robots.txt?
Is there a way your team can clear the cache on your side for the server?
I’m a community member, just like you.
However, if you’re a Ghost(Pro) customer, contact support via email at support at ghost dot org.
