Hello
After years of using Wp I created a new personal blog with Ghost. I really love it but i ve some huge ranking problem.
I know that you have to work to rank good but in my case a lot of my content is not even indexed, and i ve to “force” it via webmaster tool. Every time.
Basicaly now everytime i do i post i ve to force the crawling and then force the indexing.
I ve some link coming in (not a lot but still a dozen)
I ve long - good - content
I ve no errors on Google search console
Same content on substack / linkedin get indexed
it s not indexed by exact search name + family name on google
Before moving to the main dir (from sub.domain.com to domain.com) i want to understand if all these issues are caused by the poor choice of subdomain or what else (misconfiguration?)
Where are you posting first? Is it possible you’re creating duplicate content problems or are you able to set the canonical URL on these same-content posts so it points at the original post on your website?
Additionally, be sure to submit your sitemap to Google Search Console, which is located at yoursite.com/sitemap.xml. This ensures new content can be picked up by Google.
Each of those categories will show you the pages impacted. And you can click each one to help you see what’s wrong.
Google doesn’t always index tag and author pages. They’re not very interesting and don’t have much unique content. I wouldn’t worry about those as if you have posts missing.
Right. So if you pick one of those POSTS that is crawled but not indexed, what links does it show? If none, that’s probably why you’re not getting indexed.
Not crawled surprises me, if you have your sitemaps submitted. If you pick a POST that is in not crawled status, what does the detail for that url say?
