How was Ghost installed and configured? Digital Ocean pre-configured droplet.
What Node version, database, OS & browser are you using? Node: v18.20.8, database: MySQL, looking for version number, OS: Ubuntu v22.04.5 LTS, Browser: Firefox 141.0
When running ghost backup from the command line as my non-root ghost user, The backup errors out with Response code 500 (Internal Server Error). Log below:
You can check for the latest version on GitHub here:
You are using an old Ghost-CLI version. You can update it by logging into your server and running:
sudo npm install -g ghost-cli@latest
Which is listed in the docs here:
Also if you are going to be sticking to Ghost 5, then 5.130.3 is the most current release of that version. You can upgrade to that version by logging into your server, navigating to your ghost site’s directory, and running:
I’m preparing to upgrade to Ghost 6 once 6.0.1 is out. That’s why I want to run a backup.
I’ve upgraded to 5.130.3 and run sudo npm install -g ghost-cli@latest. Now, when I run ghost backup, I get the following:
ghost-mgr@ourtwocentstravel:/var/www/ghost$ ghost backup
https://careers.ghost.org
+ sudo systemctl is-active ghost_ourtwocentstravel-com
+ sudo mkdir -p /var/www/ghost/backup
? Enter your Ghost Staff access token my_email@mail.com
>> Token must follow the "{A}:{B}" format, where A is 24 hex characters and B is 64 hex characters
Not sure what that means.
My Ghost-CLI version is now 1.28.3, and my Ghost version is now 5.130.3.
Again, thanks for the guidance!
I wish the Ghost-CLI was updated when running ghost update instead of a separate process.
[edit] I see that it’s asking for my Ghost Staff access token instead of my admin email address and password. I’m looking for where to find my Ghost Staff access token.
Go to your Ghost Blog web site, click on Settings, under General Settings, click on Staff, hover over the user you want to use to run backups (in my case, I’m the only Admin, and I’m under Owner at the top), and click on View Profile. Scroll down to the bottom and you’ll see the Staff Access token. Hover over it and click Copy.
After upgrading Ghost and the CLI, and finding and entering my Ghost Staff access token, the backup ran successfully. Thanks to those who assisted!
Ghost 6.0.1 is already out. It just updated some French translations.
If you are waiting for a point release that fixes some bugs or something in the 6.0 release, you might want to wait for 6.0.2 or 6.0.3, or 6.1. You can see the latest releases and what all was fixed/added here:
