Is there any way to track someone watching a video that is part of a post? I am embedding from Vimeo if that matters.
Not out of the box – but here is a rough idea how it could work:
You could hook up the Vimeo Player API – or specifically, the “Play” event it fires. As far as I can see on first glance (never having worked with the Vimeo API before), this would need to replace the native Ghost embed.
You’d then need a script that captures the “play” event, identifies which member is watching, and store this information somewhere.
Bit hacky – but possible.
Thanks, that’s a good place for me to start!
