Automatically post to Bluesky
Has anyone successfully managed to get Ghost posts to be shared automatically with Bluesky?
Bluesky doesn’t have a Zapier integration, so there is no “plug and play” option and it will require some coding.
The base for it would be the Bluesky API: Posting via the Bluesky API | AT Protocol
Technically, you could use the Code by Zapier integration to stitch that together. For reference, somebody wrote a tutorial on how to do it with Make, which you could use as inspiration: Connect Bluesky and MAKE.com for new posts - Jans Weblog
Interesting. Do you find Bluesky able to generate traffic?
Thanks, I’ll take a look and have a stab at it!
Don’t know, as we have only just set it up, but we brought over a large portion of our Twitter and Mastodon followers, so there are people there – like with Mastodon, we want to automate everything about it. Twitter/FB/Instagram still dominate traffic.
Figured out posting to Blue Sky with Make, it’s messy - the API does not pull image URL’s, only local assets, Make has local storage module available which saves the day.
Basically
  1. Pull Feature or Twitter Image from Ghost to local storage
  2. Resolve user with BlueSky
  3. Create a session
  4. Push the image to BlueSky, generates a blob
  5. Split up the image-blob json
  6. Post to Blue Sky
… and looks good…
I’ve also been able to do this using Node-Red. The process is exactly as @mheland describes.
I found this example helpful:
One issue I ran into is that image blobs have to be less than 1MB.
With something like this comment pulls @emilyliu.me on Bluesky
and autoposting to bsky it could be a great integration
In relation to Bluesky, I saw she posted about using Bluesky for comments which might give some insight into things, and would love to know if anyone has tried this yet Using Bluesky posts as blog comments
I guess you could use Mastodon as ‘middleware’
Feed your Ghost RSS to https://mastofeed.org/ then use https://skymoth.app/ to mirror it into Bsky
Be keen to hear if anyone gets this bsky comment thing working: https://airview.so/comments/
Hey,
I’ve been taking a look at building a custom Integration between ghost and bluesky:
Basically it’s a web server that you can startup then add it as a custom integration with the post-published webhook and it will automatically post an excerpt and a link to your post.
Currently it’s probably only going to be good for self-hosted, as it doesn’t verify that the web hook is coming from your ghost instance, but it might be good for some of you!
This mastofeed + skymoth method looks to be the easiest, and also cheapest method of getting Mastodon and Bluesky crossposting working. Playing with it this morning and at least with posts from my RSS feed it’s working great.
FWIW – I’ve been using CoSchedule since forever, but recently came up against an issue that make me start looking around.
After much experimentation, the solution that is working for me is Zapier-to-Buffer. Zapier knows when a post is published on Ghost, and can create one or more new posts from it in Buffer.
Mine is pretty customized, as I don’t want everything I post to be put on social media. So, I have Zapier filter on the tag #Buffer. If that tag exists, it then creates a post on Facebook, Threads, Mastodon, and BlueSky. Then, it waits for two days, and send the same four posts again with “ICYMI --” at the front.
Working like a charm, and pretty inexpensive.
I must be seriously confused. I thought the point of the Social Web was that what we publish on our Ghost sites would be automatically shared with other Fediverse platforms. I’m struggling to see the point, otherwise.
The term Fediverse is closely associated with the ActivityPub protocol. Several services speak ActivityPub, but Bluesky is not one of them.
Bluesky developed their own protocol, AT, which hardly anything else has adopted. One could argue that is Bluesky who should be adding support for the many platforms that support ActivityPub rather than having many services support a protocol that is used practically only by Bluesky.
In the meantime, there are bridging services that translate back and forth between the two protocols to varying degrees.
Pardon the necrobump, but the term Atmosphere is used within the AT Proto/Atmospheric ecosystem for those asking.
