Block Quotes are Bigger in Markdown Editor
How can I make the size of block quotes in the markdown editor be the same as the one in the default editor for casper theme?
Here is what I’m talking about:
You’ll need to customise the theme using CSS. However you’ll want to bear in mind that the editor isn’t designed to look exactly like the published page
Yea, I was wondering where in the CSS to look, or if there is documentation on the theme or where to look in here: Ghost Handlebars Themes - Building a custom Ghost theme - Docs.
Forgive me, I’m kind of a noob at this stuff, if someone direct me towards the right direction?
@xcalibur first thing is to make sure everyone is on the same page as to the problem. As @DavidDarnes said, the theme styling is not related to what you see in the editor.
Are you reporting an inconsistency in the editor styling, or are you having issues with Casper showing blockquotes differently if they were created in a markdown vs the main editor?
Im having an issue with Casper showing blockquotes differently if they were created in markdown vs the main editor
