Absolutely a work in progress. If you have a favorite widget/embed code provider, let’s hear it! ![]()
Hi Cathy! Thank you for your blog post on using widgets inside Ghost. Do you have any insight on putting Ghost into a widget for use on other sites or applications?
The best event calendar integration I’ve found is Tockify https://tockify.com/
The paid version can sync with Google Calendar, highly customizable, pinboard / agenda views, Google map integration, and own domain / white label option.
You can pull posts with Javascript from the read-only Content API and embed
wherever you want…
View the source on this page to see how this works…
https://www.helander.stream/banner/lastposts/
