Hi hosted on ghostpro using default casper theme, the bookmark card shows the image in the editor but on site there is no image?
Editor:
Site:
Any fix?
Hey @WAFO, tested the same link on Casper and it displays the bookmark card image without any issue. Would you mind sharing your site URL?
Sure. https://www.watchandfindout.com/wot-a-week-vol-iv/
And thanks for taking a look🙂
Did some inspection in the HTML and it looks like you’re using fluidbox for lightbox effect on images. The library affected the bookmark thumbnail as well. Try initializing the library only on the post images excluding the bookmark thumbnail.
