Hello, people!
I never managed to setup properly mail settings in Ghost since last year and gave up. Now I tried once again and well it’s not working and I am out of ideas.
- We are been using Mailgun on our main domain for a long time and it works fine
- Ghost runs on subdomain blog.domain.tld
- Then I try to modify " From address" in Labs there is short “sending” and then red button with “Retry”. No matter what kind of “From address” I try to make.
- All emails are being sent with @subdomain.domain.tld address. There is just emptiness before @.
- IP addresses are whitelisted just in case in Mailgun (VPS and CloudFlare)
- If I try to subscribe with Gmail domain it says " Please enter a valid email address!", but works totally fine with any other domain name.
Is this so complicated, because our blog runs on subdomain? What am I missing…?
Logs than I try to modify “From address” in Labs:
[2020-06-28 12:34:37] ERROR “POST /ghost/api/v3/admin/settings/members/email/” 400 29ms
MESSAGE: Failed to send email.level: normal
“Please see Configuration - Adapt your publication to suit your needs for instructions on configuring email.”
BadRequestError: Failed to send email.
at new BadRequestError (/var/www/ghost/versions/3.21.0/node_modules/ghost-ignition/lib/errors/index.js:113:23)
at Object.query (/var/www/ghost/versions/3.21.0/core/server/api/canary/settings.js:145:23)EmailError: Failed to send email.
at EmailError.GhostError (/var/www/ghost/versions/3.21.0/node_modules/@tryghost/errors/lib/errors.js:10:26)
at new EmailError (/var/www/ghost/versions/3.21.0/node_modules/@tryghost/errors/lib/errors.js:34:20)
at createMailError (/var/www/ghost/versions/3.21.0/core/server/services/mail/GhostMailer.js:51:12)
at EventEmitter. (/var/www/ghost/versions/3.21.0/core/server/services/mail/GhostMailer.js:112:24)
at Object.onceWrapper (events.js:286:20)
at EventEmitter.emit (events.js:198:13)
at EventEmitter.emit (domain.js:448:20)
at DirectMailer. (/var/www/ghost/versions/3.21.0/node_modules/directmail/lib/mailer.js:138:30)
at QueryReqWrap.onresolve [as oncomplete] (dns.js:196:10)
Logs than I try to subscribe with Gmail address:
[2020-06-28 12:36:40] ERROR
MESSAGE: Failed to send email. Reason: Mail from command failed - 555 5.5.2 Syntax error. p9si11031054wrx.301 - gsmtp.level: normal
EmailError: Failed to send email. Reason: Mail from command failed - 555 5.5.2 Syntax error. p9si11031054wrx.301 - gsmtp.
at EventEmitter. (/var/www/ghost/versions/3.21.0/core/server/services/mail/GhostMailer.js:117:28)
at DirectMailer. (/var/www/ghost/versions/3.21.0/node_modules/directmail/lib/mailer.js:185:42)
at SMTPClient. (/var/www/ghost/versions/3.21.0/node_modules/directmail/lib/mailer.js:277:9)
at SMTPClient.emit (events.js:198:13)
at SMTPClient.EventEmitter.emit (domain.js:448:20)
at SMTPClient._onError (/var/www/ghost/versions/3.21.0/node_modules/simplesmtp/lib/client.js:373:10)
at SMTPClient._actionMAIL (/var/www/ghost/versions/3.21.0/node_modules/simplesmtp/lib/client.js:981:14)
at SMTPClient._onData (/var/www/ghost/versions/3.21.0/node_modules/simplesmtp/lib/client.js:354:29)
at Socket.emit (events.js:198:13)
at Socket.EventEmitter.emit (domain.js:448:20)
at addChunk (_stream_readable.js:288:12)
at readableAddChunk (_stream_readable.js:269:11)
at Socket.Readable.push (_stream_readable.js:224:10)
at TCP.onStreamRead [as onread] (internal/stream_base_commons.js:94:17)[2020-06-28 12:36:40] INFO “POST /members/api/send-magic-link/” 500 71ms
- What version of Ghost are you using?
Ghost version: 3.21.0
Ghost-CLI version: 1.14.1
Slightly modified version of Casper 3.0.12 - How was Ghost installed and configured?
On VPS, Ubuntu 18.04
