Can't Start Ghost Because Another Installation Ghost is Running or Port is Clash
Hello, My Website is: https://aku.jadidewa.com
I Can’t Start Ghost Because Another Installation Ghost is Running or Port is Clash.
The Error is:
(EADDRINUSE) Cannot start Ghost.
“Port 2389 is already in use by another program.”
“Is another Ghost instance already running?”
Error ID:
d9deab90-653d-11e9-a98b-3f8c48913f7f
InternalServerError: (EADDRINUSE) Cannot start Ghost.
at new GhostError (/home/jadidewa/aku.jadidewa.com/versions/2.20.1/core/server/lib/common/errors.js:10:26)
at Server. (/home/jadidewa/aku.jadidewa.com/versions/2.20.1/core/server/ghost-server.js:79:30)
at emitOne (events.js:116:13)
at Server.emit (events.js:211:7)
at emitErrorNT (net.js:1380:8)
at _combinedTickCallback (internal/process/next_tick.js:139:11)
at process._tickCallback (internal/process/next_tick.js:181:9)
I have replaced various ports , but the result is same.
Thx :smiley: I need your help guys :wink:
How many ghost blogs do you have on the server?
What is the ghost status result? Go to ghost root directory and enter as followed.
ghost status
Best Regards,
Fred
