Changed URL but SSL still using old URL
Hi All,
I have had Ghost running for a while with SSL configured on a domain. I changed the domain today and then reran the ghost setup SSL and it keeps telling me that a SSL setup already exists. If I browse to the site using the new domain it gives me a certificate error as it is still using the old certificate for the old domain. How do I force Ghost and LetsEncrypt to generate a new SSL with the new domain?
So far I have done the following:
Ghost setup url https://dev-on-demand.tech
ghost setup SSL
ghost restart
The new domain is being used fine, just can’t get a new certificate, have even tried deleting the letsencrypt folder and no joy.
I have ghost and the ghost-cli on the latest version, I am also testing in incognito mode as well for now to avoid any browser plugin and cache issues.
The steps for changing a url are here: https://docs.ghost.org/faq/change-configured-site-url/#change-the-configuration
If you ran ghost setup url <url> rather than ghost config url <url>, I’m not sure that you actually change the domain for the site correctly?
If you retry these steps and still have difficulty, Ghost-CLI wraps acme.sh which you can call directly. There are some details in the knowledge base here: Ghost-CLI - A fully loaded tool for installation and configuration
