Changing currency value of dashboard MRR reporting?
Is there a way I can change the MRR reporting value on the dashboard from USD to GBP?
Over 3 years later and still no solution?
Well, it’s not a currency, it’s an indicator, a ratio. At least, try to be friendly and polite with the people working on Ghost. It’s doesn’t need a solution because it’s not an issue.
What is MRR?
Monthly Recurring Revenue, commonly abbreviated as “MRR” is all of your recurring revenue normalized into a monthly amount. It’s a metric usually used among subscription and SaaS companies.
It’s a way to average your various pricing plans and billing periods into a single, consistent number that you can track the trend of over time.
How to Calculate MRR
The MRR calculation is pretty simple. You need to multiply your average revenue per account by the total number of customers for that month.
Source: How To Calculate MRR | Baremetrics Academy
What are you talking about? If th dashboard is showing my MRR in USD and I am in the UK, my currency therefore is GBP. USD metrics are USELESS
OK, I also get your point, for instance, in my case is even worst, picture this: If you can’t enable Stripe in your country (Chile in this case), all monetisation features are absolutely useless, ergo related metrics and so on. Anyways, I try to be respectful with the people behind this amazing open source platform, starting by avoid phrases like “Over 3 years later and still no solution?”, which I think it’s quite aggressive, like they are some kind of lazy people or incompetent ones.
This is what I’m trying to tell you, invite you to be more respectful with them and their work.
I’m not trying to offend you or being “morally superior”, just a friendly call to cultivate healthier ecosystems and communities.
Regards!
