Command 'ghost' not found
I’m trying to install Ghost latest version according to How to install & setup Ghost on Ubuntu 20.04 or 22.04
I have:
Ubuntu 18.04.1 LTS
nginx/1.14.0 (Ubuntu)
Node.js v8.12.0
mysql Ver 14.14 Distrib 5.7.24
I created myuser, added him to sudo group and switched to myuser
Installed node.js, nginx, mysql then did:
$ sudo npm install ghost-cli@latest -g
npm WARN deprecated cross-spawn-async@2.2.5: cross-spawn no longer requires a build toolchain, use it instead
/usr/bin/ghost → /usr/lib/node_modules/ghost-cli/bin/ghost
  • ghost-cli@1.9.7
    updated 1 package in 13.7s
$ npm root -g
$ ghost
Command ‘ghost’ not found, did you mean:
$ sudo ls -ld /usr/lib/node_modules/ghost-cli/
drwxr-x— 6 root root 4096 Nov 1 14:56 /usr/lib/node_modules/ghost-cli/
If I do:
$ sudo chown myuser: /usr/lib/node_modules/ghost-cli
I get:
$ ghost
module.js:550
throw err;
Error: Cannot find module ‘yargs’
When I check npm modules:
$ npm ls -g
/usr/lib
├─┬ ghost-cli@1.9.7
│ ├── UNMET DEPENDENCY abbrev@1.1.1
│ ├── UNMET DEPENDENCY adm-zip@0.4.11
│ ├── UNMET DEPENDENCY bluebird@3.5.1
│ ├── UNMET DEPENDENCY chalk@2.4.1
│ ├── UNMET DEPENDENCY cli-table3@0.5.0
│ ├── UNMET DEPENDENCY debug@3.1.0
│ ├── UNMET DEPENDENCY decompress@4.2.0
│ ├── UNMET DEPENDENCY download@7.1.0
│ ├── UNMET DEPENDENCY execa@0.10.0
│ ├── UNMET DEPENDENCY find-plugins@1.1.7
│ ├── UNMET DEPENDENCY fkill@5.3.0
│ ├── UNMET DEPENDENCY fs-extra@7.0.0
│ ├── UNMET DEPENDENCY generate-password@1.4.0
│ ├── UNMET DEPENDENCY global-modules@1.0.0
│ ├── UNMET DEPENDENCY got@8.3.2
│ ├── UNMET DEPENDENCY inquirer@6.1.0
npm ERR! missing: semver@5.5.0, required by ghost-cli@1.9.7
npm ERR! missing: shasum@1.0.2, required by ghost-cli@1.9.7
npm ERR! missing: stat-mode@0.2.2, required by ghost-cli@1.9.7
npm ERR! missing: strip-ansi@4.0.0, required by ghost-cli@1.9.7
npm ERR! missing: symlink-or-copy@1.2.0, required by ghost-cli@1.9.7
npm ERR! missing: systeminformation@3.42.9, required by ghost-cli@1.9.7
npm ERR! missing: tail@1.3.0, required by ghost-cli@1.9.7
npm ERR! missing: validator@7.2.0, required by ghost-cli@1.9.7
npm ERR! missing: yargs@12.0.1, required by ghost-cli@1.9.7
npm ERR! missing: yarn@1.9.4, required by ghost-cli@1.9.7
Can you help me out with the installation?
Can someone at least post what should be the ownership of npm installed modules?
Or maybe how to do the installation with yarn?
