Weird thing … i followed all the steps as instructed in the official tutorial and when i run the ghost install command or ghost -v i get the error that the ghost command is not found
This happens for the sudo user, however the command(s) is(are) recognized by the root user, where i get an output of ghost version installed
I just dont know what to do now … stuck. I tried running an alternative way, which is ghost install --dir /path/directory from inside root user but i get the instruction that i must run this as a regular user.
I didnt install nvm. It’s text book installation from the official guide from docs/install/ubuntu
Ran all the installation commands with the sudo user
The npm location for root ( output of command npm root -g ) is /usr/lib/node_modules
The node -v can be seen from the sudo user side . Same goes for npm -v … i can see this too from the sudo user
Nodejs Version: 18.19.1
Npm Version 10.2.4
Ghost Version (seen from root user only) 1.26.0
Ubuntu server 2204 (upgraded to pro account)
