Same here. Local ghost install. Create user(s). Lock out other users. No email configured. Not sure exactly where to go with this.
[grid]
[grid]
@justinacolmena , For a local install and if you just want to create site members, just do that in the dashboard. (I assume you want members not users, because that’s what your image shows.)
? Enter your blog URL: http://localhost:2368/
? Enter your MySQL hostname: localhost
? Enter your MySQL username: ghost
Ghost was installed successfully! To complete setup of your publication, visit:
http://localhost:2368/ghost/
So the URI /ghost/ is the key to completing the setup.
Ah. I don’t think you’re posting on a thread that makes sense (the OP had a totally different question), but I’m glad you got it figured out.
(EDIT: Forked this discussion from the initial thread which was about a totally different question, as far as I can tell - sorry for any discontinuity that results.)
So far so good, with Caddy to automatically configure ssl and reverse-proxy open internet connections at large to the “local” install at 127.0.0.1:2368. Configure the external url in config.production.json and on the theme site navigation.
Email received from localhost installation. Actually
$ ssh -L 127.0.0.1:2368:127.0.0.1:2368 myuser@somehost.example.org
Must manually specify 127.0.0.1 rather than localhost because ghost is running on IPv4 loopback only, and IPv6 connections will stall if it is not listening on [::1]:2368 as well. So actually that was a remote install, but proxied over ssh to access locally. Once that was working, I added a rule reverse_proxy 127.0.0.1:2368 to the server section in the Caddyfile.
