I began trying to spin up a second instance of ghost on my same digital ocean droplet, and in the process ended up deciding to uninstall ghost, node, npm, etc. and reinstall. (I knew this would drop my existing Ghost instance, but figured I could just run ghost start again)
Now I’m not able to get my old instance OR my new instance running. I CAN get it to spin up with ghost run, but ghost start doesn’t work at all. Below you can see my error, which is saying it can’t connect to the ghost port 2369. I’ve double checked the config and my NGINX .conf file, both of which are pointing to port 2369.
Since I’m not having any luck even with my brand new ghost install, I don’t think trashing this instance and transferring the data on a new instance would even work. At this point, I’m all out of ideas ![]()
- What’s your URL?
- What version of Ghost are you using?
1.25.4
- What configuration?
I’m not sure what this means. Here’s the debug information that spit out:
OS: Ubuntu, v18.04.3 LTS
Node Version: v12.14.1
Ghost Version: 1.25.4
Ghost-CLI Version: 1.13.1
Environment: production
Command: 'ghost start'
- What browser?
Chrome
Here’s what initially logs:
+ sudo systemctl is-active ghost_coursework-vschool-io
+ sudo systemctl reset-failed ghost_coursework-vschool-io
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
+ sudo systemctl start ghost_coursework-vschool-io
+ sudo systemctl stop ghost_coursework-vschool-io
✖ Starting Ghost: coursework-vschool-io
A GhostError occurred.
Message: Ghost did not start.
Suggestion: journalctl -u ghost_coursework-vschool-io -n 50
Additional log info available in: /home/bob/.ghost/logs/ghost-cli-debug-2020-01-31T16_22_05_811Z.log
You can always refer to https://ghost.org/docs/api/ghost-cli/ for troubleshooting.
Here’s the result of running the journalctl command:
Hint: You are currently not seeing messages from other users and the system.
Users in groups 'adm', 'systemd-journal' can see all messages.
Pass -q to turn off this notice.
-- Logs begin at Wed 2019-12-11 17:20:00 UTC, end at Fri 2020-01-31 07:40:38 UTC. --
-- No entries --
Here’s what logs to the ghost logs:
Stack: Error: Ghost did not start.
at /usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:150:28
at processTicksAndRejections (internal/process/task_queues.js:94:5)
Original Error Message:
Message: connect ECONNREFUSED 127.0.0.1:2369
Stack: Error: connect ECONNREFUSED 127.0.0.1:2369
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1134:16)
Try to start my ghost instance ![]()
