- What’s your URL?
woosik.me - What version of Ghost are you using?
Ghost-CLI version: 1.12.0
Ghost version: 3.0.2 (at /var/www/ghost)
What configuration?
What browser?
Chrome -
Hi my ghost doesn’t work.
recently, I wrote on command line
ghost update etc (before I wrote this command line, It worked well)
this is my console
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
- sudo systemctl is-active ghost_woosik-me
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
- sudo systemctl start ghost_woosik-me
☱ Starting Ghost
starting ghost command is fixed on my console…
but if I change directory that is installed my local ghost, ghost start command works
ghost-mgr@ghost-blog : /var/www/ghost/ghost-blog $ ghost start
Found a development config but not a production config, running in development mode instead
Ensuring user is not logged in as ghost user [skipped]
Checking if logged in user is directory owner [skipped]
Validating config
Starting Ghost
Your admin interface is located at:
but when I connect on my web, it doesn’t work
this error
ERR_CONNECTION_REFUSED
I’ve already checked my hosts file… but there is no problem
version is Ghost-CLI version: 1.12.0, Ghost version: 3.0.2 (at /var/www/ghost), node, nodejs v10.17.0
please help me T.T
