Custom Author Box in Dawn Theme?
I was wondering if someone successfully added some more information about the author in the author box below each post. Currently, there is only the author image shown. No name, no bio, nothing.
Since Google is using the author’s experience as ranking factor, I would like to add more information here to make it easier for google to identify the author.
I have tried adding author object attributes myself, but design wise, it doesn’t seem to be working well for me.
So if there is anyone who can help add name and bio of the author below each post and just the name on top of each post, without breaking the design - feel free to reach out. I’d also be happy to pay for a good code snippet.
Here you go :slight_smile:
Desktop:
And mobile:
The modifications:
In the partials/content.hbs I have modified the div with class single-footer-middle to this, adding the author name and bio:
        <div class="single-footer-middle">
        {{#if @custom.show_author}}
            <div class="single-footer-top">
                <h3 class="single-footer-title">Published by:</h3>
                <div class="author-list">
                    {{#foreach authors}}
                    <div class="author-image-placeholder u-placeholder square">
                        <a href="{{url}}" title="{{name}}">
                            <img class="author-image u-object-fit" src="{{img_url profile_image size="xs"}}" alt="{{name}}" loading="lazy">
                        </a>
                    </div>
                    <div class="author-meta-info">
                        <h4 class="author-name">
                            <a href="{{url}}" title="{{name}}">{{name}}</a>
                        </h4>
                        <span class="author-bio">{{bio}}</span>
                    </div>
                    {{/foreach}}
                </div>
            </div>
        {{/if}}
        </div>
Additionally, I have added this CSS via a code injection directly in the Ghost settings:
        <style>
            .author-list {
                display: flex;
                flex-direction: row;
                justify-content: flex-start;
                align-items: flex-start;
                gap: 2rem;
                padding: 0 2rem;
            .author-image-placeholder.u-placeholder.square {
                width: 8rem;
                height: 8rem;
            .author-meta-info {
                flex-grow: 1;
            @media (max-width: 768px) {
                .author-list {
                    flex-direction: column;
                    align-items: center;
                    text-align: center;
        </style>
Hope this achieves what you were looking for :slight_smile:
Wow! Thank you so much @jannis! Looks great, thank you so much.
Have you also added your name above the posts as part of the meta information?
No, seems like I missed that part in your original post.
To add the author to the meta info above the post, just extend the div with the class single-meta as follows:
<div class="single-meta">
        <span class="single-meta-item single-meta-date">
            <time datetime="{{date format="YYYY-MM-DD"}}">
                {{date published_at}}
            </time>
        </span>
        {{#if reading_time}}
            <span class="single-meta-item single-meta-length">
                {{reading_time}}
            </span>
        {{/if}}
        {{#primary_tag}}
            <span class="single-meta-item single-meta-tag">
                <a class="post-tag post-tag-{{slug}}" href="{{url}}">
                    {{name}}
                </a>
            </span>
        {{/primary_tag}}
               <span class="single-meta-item single-meta-author">
                   <a class="post-author" href="{{url}}">
                       by {{name}}
                   </a>
               </span>
           {{/foreach}}
       {{/if}}
</div>
For that part you wouldn’t need any additional CSS, though you could use the single-meta-author class to style it however you’d like :slight_smile:
Super cool! Thanks :pray:
thanks you for provide authorbox its cool.
1- I tried but it’s not working. Can you send content.hbs?
2- And another question is where do you put to css in code injection module? To site header or site footer?
Here is the entire file:
<article class="single {{post_class}}">
    {{#match @page.show_title_and_feature_image}}
        <header class="single-header gh-canvas">
            {{#is "post"}}
                    </time>
                </span>
                        {{reading_time}}
                    </span>
                {{/if}}
                {{#primary_tag}}
                            {{name}}
                        </a>
                    </span>
                {{/primary_tag}}
                                by {{name}}
                            </a>
                        </span>
                    {{/foreach}}
                {{/if}}
            </div>
            {{/is}}
            <h1 class="single-title">{{title}}</h1>
            {{#if custom_excerpt}}
                <div class="single-excerpt">
                    {{custom_excerpt}}
                </div>
            {{/if}}
            {{#if feature_image}}
            {{#unless no_image}}
                <figure class="single-media kg-width-{{width}}">
                    <div class="u-placeholder horizontal">
                        <img
                            class="u-object-fit"
                            srcset="{{> srcset}}"
                            sizes="(min-width: 1200px) 920px, 92vw"
                            src="{{img_url feature_image size="l"}}"
                            alt="{{#if feature_image_alt}}{{feature_image_alt}}{{else}}{{title}}{{/if}}"
                    </div>
                    {{#if feature_image_caption}}
                        <figcaption>{{feature_image_caption}}</figcaption>
                    {{/if}}
                </figure>
            {{/unless}}
            {{/if}}
        </header>
    {{/match}}
    <div class="single-content gh-content gh-canvas">
        {{content}}
    </div>
    {{#is "post"}}
    <div class="gh-canvas">
    <footer class="single-footer">
        <div class="single-footer-left">
        {{#prev_post}}
            <div class="navigation navigation-previous">
                <a class="navigation-link" href="{{url}}" aria-label="Previous post">
                    {{> "icons/arrow-left"}}
                </a>
            </div>
        {{/prev_post}}
        </div>
                        </a>
                    </div>
                        </h4>
                    </div>
                    {{/foreach}}
                </div>
            </div>
        {{/if}}
        </div>
        <div class="single-footer-right">
        {{#next_post}}
            <div class="navigation navigation-next">
                <a class="navigation-link" href="{{url}}" aria-label="Next post">
                    {{> "icons/arrow-right"}}
                </a>
            </div>
        {{/next_post}}
        </div>
    </footer>
    </div>
    {{/is}}
</article>
And you put the CSS into the header of the site.
I put that code in Header via injection but it didn’t work. Which CSS?
No. The code I posted in my last post is the content.hbs. You need to download your theme, edit the content.hbs, and re-upload it.
You put the CSS into the code injection. I posted that here:
Its worked, thank you.
