Custom cards to allow copying code / prompts
I understand that I can use the HTML card / snippets to create custom cards. However if I want to change contents i must (as an editor) always work my way through code. Also the content is not visible in the editor mode.
Is there a more elegant way to create custom cards that offer a better and more robust editor experience?
What do you mean? I use a lot of custom html cards, and yes I do have to open the card to make edits to it. But I am unsure what you mean by there being another way to edit it after it’s created.
If you’re not good at code, just tell ChatGpt what you want and it will create the code for you in seconds and works beautifully.
