Custom Text for Subscribe buttons
Greetings, I’d like to add custom text to my ‘subscribe’ button. I’m using latest Source theme. The generic ‘subscribe’ can be changes on the floating button in lower right but not on footer and home page forms. Any suggestions? And if this isn’t possible are there any themes that allow this?
my site
Pretty sure you can change it in the settings page of /ghost
If I recall correctly, it should be under your portal settings. You change change the text and icon there.
Thanks for the reply. I’ve looked at that and don’t see a way to change text other than the floating button on Botton right of site. I can change heading and description of signup form but not the button.
This would require either editing the theme or else a little JavaScript to replace the text on the page with new text (which is not my first choice, but removes the need to edit the theme)
Thanks. Not much of a tech guy so I guess I’ll leave it for now. You know if there are any themes that allow this?
