Digital Ocean LetsEncrypt SSL not update, Solution is here
Today my LetsEncrypt certificate was expired and I tried to renew it with ghost setup ssl. But it was not successful. Then I tried sudo certbot renew it worked fine and save my day.
I hope it will save your day also.
Ps.
  • You have to logout from ghost manager user and get root privilege’s
  • You should run it in the root folder.
Tried it - does not work. gives below error:
tSaving debug log to /var/log/letsencrypt/letsencrypt.log
No renewals were attempted.
Did you logged as root and execute the command at / ?
yes i am logged in as root
here’s what my command prompt looked like:
root@website:~# sudo certbot renew
any help here @thimiraonline pls mate?
