I’m having similar problems - the auto-renew in cron looks good.
If I try ghost setup ssl-renew > log then log just contains:
[12:44:33] Checking for Ghost-CLI updates [started]
[12:44:33] Checking for Ghost-CLI update[s [completed]
[12:44:33] Ensuring correct ~/.config folder ownership [started]
[12:44:33] Ensuring correct ~/.config folder ownership [completed]
Manually renewing certs with
/etc/letsencrypt/acme.sh --home "/etc/letsencrypt" --renew-all --debug
results in (for each of my Ghost blogs)
[Mon 11 Nov 12:47:43 GMT 2019] di=‘/etc/letsencrypt/travels.two-drifters.co.uk/’
[Mon 11 Nov 12:47:43 GMT 2019] d=‘travels.two-drifters.co.uk’
[Mon 11 Nov 12:47:43 GMT 2019] Using config home:/etc/letsencrypt
[Mon 11 Nov 12:47:43 GMT 2019] DOMAIN_PATH=‘/etc/letsencrypt/travels.two-drifters.co.uk’
[Mon 11 Nov 12:47:43 GMT 2019] Renew: ‘travels.two-drifters.co.uk’
[Mon 11 Nov 12:47:43 GMT 2019] Using ACME_DIRECTORY: https://acme-v01.api.letsencrypt.org/directory
[Mon 11 Nov 12:47:43 GMT 2019] _init api for server: https://acme-v01.api.letsencrypt.org/directory
[Mon 11 Nov 12:47:43 GMT 2019] ACME_KEY_CHANGE=‘https://acme-v01.api.letsencrypt.org/acme/key-change’
[Mon 11 Nov 12:47:43 GMT 2019] ACME_NEW_AUTHZ=‘https://acme-v01.api.letsencrypt.org/acme/new-authz’
[Mon 11 Nov 12:47:43 GMT 2019] ACME_NEW_ORDER=‘https://acme-v01.api.letsencrypt.org/acme/new-cert’
[Mon 11 Nov 12:47:43 GMT 2019] ACME_NEW_ACCOUNT=‘https://acme-v01.api.letsencrypt.org/acme/new-reg’
[Mon 11 Nov 12:47:43 GMT 2019] ACME_REVOKE_CERT=‘https://acme-v01.api.letsencrypt.org/acme/revoke-cert’
[Mon 11 Nov 12:47:43 GMT 2019] Le_NextRenewTime=‘1571355119’
[Mon 11 Nov 12:47:43 GMT 2019] _on_before_issue
[Mon 11 Nov 12:47:43 GMT 2019] Le_LocalAddress
[Mon 11 Nov 12:47:43 GMT 2019] Check for domain=‘travels.two-drifters.co.uk’
[Mon 11 Nov 12:47:43 GMT 2019] _currentRoot=‘/var/www/travels/system/nginx-root’
[Mon 11 Nov 12:47:43 GMT 2019] _saved_account_key_hash is not changed, skip register account.
[Mon 11 Nov 12:47:43 GMT 2019] Read key length:
[Mon 11 Nov 12:47:43 GMT 2019] _createcsr
[Mon 11 Nov 12:47:43 GMT 2019] Single domain=‘travels.two-drifters.co.uk’
[Mon 11 Nov 12:47:43 GMT 2019] Getting domain auth token for each domain
[Mon 11 Nov 12:47:43 GMT 2019] Getting webroot for domain=‘travels.two-drifters.co.uk’
[Mon 11 Nov 12:47:43 GMT 2019] _w=‘/var/www/travels/system/nginx-root’
[Mon 11 Nov 12:47:43 GMT 2019] Getting new-authz for domain=‘travels.two-drifters.co.uk’
[Mon 11 Nov 12:47:43 GMT 2019] Try new-authz for the 0 time.
[Mon 11 Nov 12:47:43 GMT 2019] url=‘https://acme-v01.api.letsencrypt.org/acme/new-authz’
[Mon 11 Nov 12:47:43 GMT 2019] payload=‘{“resource”: “new-authz”, “identifier”: {“type”: “dns”, “value”: “travels.two-drifters.co.uk”}}’
[Mon 11 Nov 12:47:44 GMT 2019] RSA key
[Mon 11 Nov 12:47:44 GMT 2019] GET
[Mon 11 Nov 12:47:44 GMT 2019] url=‘https://acme-v01.api.letsencrypt.org/directory’
[Mon 11 Nov 12:47:44 GMT 2019] timeout
[Mon 11 Nov 12:47:44 GMT 2019] _CURL='curl -L --silent --dump-header /etc/letsencrypt/http.header ’
[Mon 11 Nov 12:47:44 GMT 2019] ret=‘0’
[Mon 11 Nov 12:47:44 GMT 2019] POST
[Mon 11 Nov 12:47:44 GMT 2019] url=‘https://acme-v01.api.letsencrypt.org/acme/new-authz’
[Mon 11 Nov 12:47:45 GMT 2019] _CURL='curl -L --silent --dump-header /etc/letsencrypt/http.header ’
[Mon 11 Nov 12:47:45 GMT 2019] _ret=‘0’
[Mon 11 Nov 12:47:45 GMT 2019] code=‘400’
[Mon 11 Nov 12:47:45 GMT 2019] The new-authz request is ok.
[Mon 11 Nov 12:47:45 GMT 2019] new-authz error: {“type”:“urn:acme:error:badNonce”,“detail”:“JWS has no anti-replay nonce”,“status”: 400}
[Mon 11 Nov 12:47:45 GMT 2019] pid
[Mon 11 Nov 12:47:45 GMT 2019] No need to restore nginx, skip.
[Mon 11 Nov 12:47:45 GMT 2019] _clearupdns
[Mon 11 Nov 12:47:45 GMT 2019] skip dns.
[Mon 11 Nov 12:47:45 GMT 2019] _on_issue_err
[Mon 11 Nov 12:47:45 GMT 2019] Please add ‘–debug’ or ‘–log’ to check more details.
[Mon 11 Nov 12:47:45 GMT 2019] See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub
[Mon 11 Nov 12:47:45 GMT 2019] socat doesn’t exists.
[Mon 11 Nov 12:47:45 GMT 2019] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.0k 28 May 2019
apache:
apache doesn’t exists.
nginx:
nginx version: nginx/1.10.3
built with OpenSSL 1.1.0f 25 May 2017 (running with OpenSSL 1.1.0k 28 May 2019)
TLS SNI support enabled
configure arguments: --with-cc-opt=‘-g -O2 -fdebug-prefix-map=/build/nginx-xpG2T2/nginx-1.10.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2’ --with-ld-opt=‘-Wl,-z,relro -Wl,-z,now’ --prefix=/usr/share/nginx --conf-path=/etc/nginx/nginx.conf --http-log-path=/var/log/nginx/access.log --error-log-path=/var/log/nginx/error.log --lock-path=/var/lock/nginx.lock --pid-path=/run/nginx.pid --modules-path=/usr/lib/nginx/modules --http-client-body-temp-path=/var/lib/nginx/body --http-fastcgi-temp-path=/var/lib/nginx/fastcgi --http-proxy-temp-path=/var/lib/nginx/proxy --http-scgi-temp-path=/var/lib/nginx/scgi --http-uwsgi-temp-path=/var/lib/nginx/uwsgi --with-debug --with-pcre-jit --with-ipv6 --with-http_ssl_module --with-http_stub_status_module --with-http_realip_module --with-http_auth_request_module --with-http_v2_module --with-http_dav_module --with-http_slice_module --with-threads --with-http_addition_module --with-http_geoip_module=dynamic --with-http_gunzip_module --with-http_gzip_static_module --with-http_image_filter_module=dynamic --with-http_sub_module --with-http_xslt_module=dynamic --with-stream=dynamic --with-stream_ssl_module --with-mail=dynamic --with-mail_ssl_module --add-dynamic-module=/build/nginx-xpG2T2/nginx-1.10.3/debian/modules/nginx-auth-pam --add-dynamic-module=/build/nginx-xpG2T2/nginx-1.10.3/debian/modules/nginx-dav-ext-module --add-dynamic-module=/build/nginx-xpG2T2/nginx-1.10.3/debian/modules/nginx-echo --add-dynamic-module=/build/nginx-xpG2T2/nginx-1.10.3/debian/modules/nginx-upstream-fair --add-dynamic-module=/build/nginx-xpG2T2/nginx-1.10.3/debian/modules/ngx_http_substitutions_filter_module
socat:
[Mon 11 Nov 12:47:45 GMT 2019] Return code: 1
[Mon 11 Nov 12:47:45 GMT 2019] Error renew travels.two-drifters.co.uk.
acme.sh is v2.7.5
I tried updating one of my blogs to the latest Ghost - this needed ghost-cli updating of course then worked OK, but didn’t change the acme.sh version, nor fix any problems,
It was all working until at least Sept 2019 (as seen from /etc/letsencrypt/acme.sh --home “/etc/letsencrypt” --list)
One thing that may be a cause I that I changed ISPs around that time and my sites now have a different external IP address.
Any thoughts on how to fix. Plan B will be to backup sites, images and themes and then wipe and reinstall - I don’t really want to do this!!!
