I just signed up for Ghost. Reading documentation is still confusing. I’d like to test locally, but I’m not sure if I need dedicated box or I can run instance of Ghost on my workstation ( Debian 8)? Do I have to have Ubuntu?
( install instructions list Ubuntu as supported OS). What else do I need to install? Can someone can point me to the right direction?
You can use a local install!
Do I have to install sqlite3 before? What about Node.js? I also need to install it before?
You just need node.js LTS (v6 / v8) installed - The CLI (which you will install as part of the steps) will install Ghost for you via ghost install local, and one of the dependencies that’s installed is sqlite3
I would also strongly recommend to run Ghost within docker. That what I do to manage all the Ghost themes I manage.
Install docker locally, then follow step 4 from: Import from wordpress to ghost 2.0 - #15 by pascalandy
Cheers!
Thanks for suggestion. How do I install docker?
Simply Google it and you you find: Get Docker | Docker Documentation
Cheers!
