I notice that everytime i run $ghost install local, I end up with a directory ~380mb in size, which means for every project I’m building on ghost, I need that amount of disk space.
I’m currently working on older hardware and limited disk space. Also data costs per gb here and I’m assuming $ghost install local downloads the entire codebase and dependencies everytime i run it. Is there a way for me to reduce disk space by installing Ghost via pnpm so that node_modules are shared? I installed ghost cli via pnpm.
Then edit config.dev…json and .ghost-cli. ghost1 & ghost2 use 2.8mb in disk space.
This seems to be working, but I’m sure its not considered a good practice nor the best way to reduce disk space usage, considering the manual interventions and future potential issues when using ghost-cli
I had to look up what “WSL distro” means 37x~380mb certainly does add up. I’m busy working on two Ghost+Astro projects using the symlinked method and everything seems to be running smooth.
Editing the ~/.ghost/config file just alerts ghost cli that there is another install so that when you run $ghost ls, all of your Ghost projects are listed.
I’d wait a little for more knowledgeable Ghost engineers to chime in before adjusting your setup though
