I have three sites hosted on one Digital Ocean droplet. All three sites are up and running on 4.4.0 and CLI 1.17.0.
When running ghost doctor, one site runs through the list without issue. Two of the three sites put out i Validating config [skipped].
The sites are running fine, but if the above is an issue, I’d like to solve it before it becomes a problem.
Thanks.
One other thing (which may not be related): All three sites respond to ghost status with No installed ghost instances found, but all ghost commands work fine.
Did you ever find a solution? Because I have the same problem and it might be related to login issues we’re experiencing.
You’re bumping a 5 year old thread, from two major versions ago. If you need some help, please start a new thread that shares all the details about your hosting setup and your problem.
