EACCES: permission denied, open ‘/var/www/ghost/.ghost-cli
I’m trying to update my ghost to the latest version 4.0
Here’s more info on what I did:
Running ghost update:
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking for available migrations
An error occurred.
Message: 'EACCES: permission denied, open '/var/www/ghost/.ghost-cli''
    OS: Ubuntu, v16.04
    Node Version: v6.11.5
    Ghost-CLI Version: 1.9.8
    Environment: production
    Command: 'ghost update'
Additional log info available in: /home/vikash/.ghost/logs/ghost-cli-debug-2018-12-01T10_45_40_015Z.log
This is what I got for Ghost doctor:
✔ Checking logged in user
✔ Checking operating system compatibility
+ sudo systemctl is-active ghost_ip.address
Instance is currently running
ℹ Validating config [skipped]
I’m not really sure how to get over this EACCES issue. Any help is gladly appreciated. :slight_smile:
Also published here
My first guess is that a different user installed ghost. If you run ls -al /var/www/ghost/.ghost-cli you can see who the owner user is. Try switching to that user and updating
Somewhy Digital Ocean manual worked for my Jino server instance:
sudo mkdir -p /home/<user>/.ghost/
sudo chown <user>:<user> /home/<user>/.ghost
sudo mv /root/.ghost/config /home/<user>/.ghost/config
sudo chown <user>:<user> /home/<user>/.ghost/config
sudo cd /var/www/ghost
sudo  find . -group root -user root -exec chown <user>:<user> {} \;
